Re: Torque vs. HP
goggomobil;170076 said:
OK agree redline and optimum very close perhaps few hundred or even tens of rpm from redline, so shift at redline
Often the ideal is not just tens or hundreds from redline, but tens or hundreds
past redline. Former allows free choice both sides of ideal, latter constrained by redline on the far side. This is an important difference.
Glad you brought up Visual and aural cues - both human senses, contribute towards "feel". Are you recognising the importance of sensory input now?
No, because even combined with other nerve and muscle input, they are inaccurate in terms of sensing longitudinal accelaration. The senses sometimes even conflict.
Did I say take the tacho out of the car or avoid looking at it? Point (1) in my previous post; agree - shift at redline (use tacho).
You said you had many other things to do while driving.
Difference between optimum and redline small by your arguments, so shift at redline, especially on sporty or racing engine.
No, what I said was, difference might be small, but difference almost always lies between redline and a point
past redline (in which case we are still constrained by redline) - so shift at redline. There is a significant difference between what you say I say, and what I actually say.
No I did not, I have agreed with all your statements above - which is to shift at redline. I suggested that trying to shift at the optimum which is close to but not actually at the redline and which is at different rpm for each gear ratio is anal.
The idea that optimum is going to fall 2, 10, or 20 RPM short of redline is a figment of your imagination. Do the math and see what the exceptions are, and when the exceptions occur, how far they are from redline, and whether this number can be differentiated and shifted on.
Did I say no time to glance at the tacho? I meant to sufficiently accurately read the tacho to get close to the optimum points you will need to more than just glance at your perfectly accurate tacho.
You keep making the assumption that RPM is changing too rapidly to follow and shift to and that tachos are horribly damped and inaccurate. They're there for a reason, and the quicker a car is built, the less damped and more accurate they are.
To know an optimal point, and to target it, is something a lot of people do. Just because you don't want to, or because you can't, doesn't mean others shouldn't. What you call anal, others call precise and efficient.
2 separate points,
1. I'm convinced, shift at redline so not much point in using optimum shift points (see above)
See above my reply.
[quote2. Your sweeping statement about human feel. Don't underestimate humans. If Schummi (sorry got to use him again) loses his rev counter in the middle of a race, is he still going to be quick or is he going to slow down drastically (which he should be if going by your arguments he may shift thousands of revs off optimum).[/quote]
There's no logic to this because he has already been told the optimum, and has spent prior laps shifting at the optimum, he now has markers in his head, and is not sensing acceleration to pick shift points.
Without knowledge of what the engine power delivery characteristic are, what gear ratios are, he isn't going to find the shift points and get round the track quicker than another driver of roughly equal driving capability who has been given the information. It will take him hours to figure close to optimum out. He may never get to optimum. He may feel he is there, but he won't be.
You say poor, bad inaccurate, how much accuracy is actually required??
Required to do what? Pick optimal shift points? A lot of accuracy is needed.. You can't even detect a hundredth of a G. Even if you somehow could, now you need to try out different shift patterns... huge number of permutations.. and select one that has best accel by feel. It isn't going to happen.
Any names or numbers from the study, or a reference?
Nope, no study. Just 7 out of 7 good people in a range of industries that require this knowledge. 7 out of 7 who vocally agree on these things, and 20 or so other excellent ones who hear it and do not disagree and who are also involved in industries that apply these things (including F1, LMP, GT insiders). All 30 or so of them are people who are hugely anti-error and will call anyone out on anything that is found to be false, or can be argued logically to be false.
Disagree, yaw acceleration at the limit can change quickly or not so quickly depending on the vehicle, tyres suspension design, conditions etc.
Have you ever performance driven? Your statements really convince me you have never driven hard. When you're cornering and you reach the limits, you are made very aware by yaw acceleration changing quickly. Again you raise the possibility of extreme exceptions just for the sake of doing so. The vehicle you describe would be the worst car on earth because it would push all over the place at the lowest of speeds, on the hardest of tires, as if it was on ice. You could go out and buy or rent the cheapest car on the market right now and if you drove it to its cornering limit, there will be obvious signs when you reach it.
I don't want to argue this point. This is totally different from straight forward long. accel. which gives no clear sign if you're non-optimal or optimal.
By the same token, if longitudinal acceleration changes this is also jerk. If you insist that humans can only sense quick and obvious changes in acceleration, you will have to quantify quick and obvious, and define poor, bad, inaccurate. If a proper study has been done, then there will be some quantifiable conclusions eg. the average human can sense jerk of x magnitude. You cannot just say it is known to be poor, and apply it to your specific situation, just because these engineers and pilots and whoever said it. This is not doing justice to the people who actually did the study and who no doubt put numbers to their findings.
Humans do not sense well enough to pick optimal shift points by feel... plain and simple.
I'm sure such a study exists, I just don't want to spend the time to dig it up because it is outside of my main interests, and because I am firmly convinced that I already have the truth on the issue, from all these good people. Also because I can prove it with some very quick and simple experiments. I could put you in a car and shift switch patterns arounds on you to yield total difference in 0-200km/h times of a second or more, and you wouldn't be able to rank the runs in terms of acceleration. I could do the same and keep shift patterns similar and switch maps around to vary acceleration, and out of 4 or so runs with no run closer than 0.4 seconds to the next closest run, and you wouldn't be able to rank them correctly. I could even cruise up to top gear and have different maps that yield different low accel across long periods of time, different by 0.05 G, but also different degrees of open exhaust or aero config and you wouldn't be able to rank the runs.
Next you're going to ask me to do it, but first I'll ask you to put money down for my time, and also as insurance for the car that is being abused.
Your primary school math syllabus is way ahead of mine.
You didn't learn multiplication and division in primary school?
Now if we don't see peak torque RPM peak torque must occur above
redline revs.
Contradiction?
No contradiction. Look at engines driven for max accel. They'll never see peak torque because they're operated in a range
above peak torque.
I'm not sure why you double space your text?
