Re: TPMS feedback
further more next time when you do anything to your tyre you have to tell the tyre shop you got tpms inside there otherwise they may demage your tpms,because most of the car has no tpms.
the other thing to watch out is some rim may not allow proper sitting of your tpms.
because the tpms needs a enough flat surface for the sitting of the rubber o ring otherwise it may leakout some air there![Huh :huhhuh: :huhhuh:](/forums/styles/default/xenforo/smilies/vbulletin/huh.gif)
factory fitted one has less problem unlike the after market tpms need to remove tyre out and install them (not going to be easy for those ultra low profile size like 40 and below.T6;553317 said:I ditto this. Much prefer it over the tpms that some bmws have as the latter doesn't show pressure of each tyre. If there is leak, factory tpms doesn't tell u which tyre. The Orange TPMS one will tell u.
