Trouble codes coming from my e90
[intx]
Hi guys,
I am trying to purchase an auctioned off e90 320i 2005 here in Indonesia.
I brought it to a friend who owns a a scanner and it throws codes like these :
First batch from v30 Autoboss
1. 2C71 - Oxygen Sensor after Catalytic Converter
2. 2A83 - Vanos Intake
3. 2C24 - Oxygen sensors before catalytic converter Mixed up
4. 2A88 - Vanos Exhaust
5. 2CA8 - Oxygen Sensor heating after catalytic converter
Second batch of errors
1. 5E19 - Engine management : interface
2. 5E40 - Steering Angle Sensor : Plausability
3. 5DF4 - System Voltage too low
Third Batch
1. A118 - Roadspeed signal implausible
Last Batch
1. 9C6E - Solar Sensor
Can anyone help me to diagnose what these codes means?
The car actually runs sluggishly and it haven't run as it should even compared to my e36.
I will get the car dirt cheap but i am in need to repair these stuffs.
The workshop that i dealt here deal mostly with mercedes but with bmw i dont think they experienced the e90.
Thank you
Re: Trouble codes coming from my e90
With that many errors and problems with the drive, you are better off looking for another car. No point getting a lemon and regret later.
Not sure if this is a good price but the common saying is; if it is too good to be true, it usually isn't. Your call.
yeah agree with pengful - dont just think about the repair cost - your time and effort and all.....cannot get parts, wait here wait here... its annoying, even at PML already like that - cant imagine indonesia leh - my 2 cents worth la....
bro,
If u still insist on buying the car....then from the error code,probably u have to standby
1)oxygen sensor bf and after cat $1xxx
2)cataylic converter $1300
3)vanos intake and exhaust sys $2500
4)engine management sys(dme) $1xxx
5)steering rack assembly (afs) $3xxx
6)sys voltage low(probably ur battery or alternator)
7)road speed signal(wheel speed sensor or abs unit failure)
8)solar sensor(rain/light sensor located on the w/screen)
Other electrical devices that relates to this fault code.....
Plus labour......
easily were looking at $15k-$20k....
