Uncomfortable Gear Change on F30?
Re: Uncomfortable Gear Change on F30?
Gina;1020287 said:
Wun faint but are u guys sure u dare to let me drive your car??? Hahaha
Ah yang washed and cleaned his car just for you... MTL
If you want to test drive F10 or Z4... Just contact our helpful BROs!
Hi I'm fine. That's what fellow BMW fans are for.
Cheers,
Raymond.
Gina;1020290 said:
But what is a SMT
Sequential Manual Transmission...
Electrohydraulic manual transmission is a type of semi-automatic transmission system, which uses an automated clutch unlike conventional manual transmissions where the driver operates the clutch. The clutch is controlled by electronic computers and hydraulics. To change gears, the driver selects the desired gear with the transmission shift lever, and the system automatically operates the clutch and throttle to match revs and engage the clutch again. Also, many such transmissions operate in sequential mode where the driver can only upshift or downshift by one gear at a time.
Depending on the implementation, some computer-controlled electrohydraulic manual transmissions will automatically shift gears at the right points (like an automatic transmission), while others require the driver to manually select the gear even when the engine is at the redline. Despite superficial similarity, clutchless manual transmission differ significantly in internal operation and driver's 'feel' from manumatics, the latter of which is an automatic transmission (automatics use a torque converter instead of clutch to manage the link between the engine and the transmission) with ability to signal shifts manually.
BMW offered a system simply called "sequential manual gearbox" (SMG) on the E36 M3, and later "SMG-II" on the E46 M3. The BMW SMG transmission has both automatic and manual shift modes. Inside the different modes there are different programmes, with six settings to control the upshift/downshift speed for manual operation, and five settings for automatic mode.
Later, the 3rd generation Toyota MR2 used Toyota's version, known as the "Sequential Manual Transmission" (SMT). Although it does not perform as well as the European-designed transmissions, Toyota's is the cheapest system to manufacture, and the MR2 is the least expensive car to possess a true sequential gearbox.
If I'm an old woman w dentures n wrinkles, can still test drive yr car, is it? Lol
Cheers,
Raymond.
Cheers,
Raymond.
We are gentlemen here and we don't judge, regardless of race, gender or age. Dentures don't make you a bad driver. C3PO say one.
C3PO is around there..........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
C3PO is hello kitty
If the person comes with genuine heart to want to learn or experience something, he or she can take my car for a spin. But I would appreciate if he or she can let me learn something about his or her car too.
Btw I just went Hello Kitty Town last weekend. The nail polish I did for my niece, nice?
My hair is white but ur hair whiter u long hai....
oops sorry forgot cannot scold admin.....
Your "Hello Kitty town" and "Legoland" look like replicas......
Automatic transmission still jerky? What happened to creamy, silky smooth?
Cheers,
Raymond.
I wannnnn.... to drive your sibeh swee car to hello kitty land....
Me too. But I know brobot won't take guys. I bro, let Gina and Meek go first.
Dun worry. Brobot got frens who take guys. :D
Lost to Efficiency dynamic.
Durian tree everywhere.
