-sOnG-;1006954 said:good luck to us vexxus, come to think of it , after reading other fellow beemer's problem here, ignition coils and plugs change seems a small price to pay comparing to the over hauls and engine being turned upside downs.
ac323;1006910 said:Ignition coil.....
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
SapphireSpite;1006975 said:Yep possible, same as me
Not too pricey.. like 100 per coil? Or lower?
nhc;1006998 said:I bought the BOSCH ignition coil from stockist @ 35 bucks per piece. Anyway, I have this engine shaking/vibration @ idle issue but the RPM doesnt move much then. Could it be the VANOS solenoid ? or the MAF sensor needs cleaning ? It happened after i changed my VANOS seal.
vexxus;1007053 said:
Thanks all for the assistance.
Went to workshop this morning, diagnose as no. 4 & 5 ignition coil kaput liao.. Also, electric water pump is 1 of the error from the reading..
Sian jit buah..... :verysad:
Red_Bean_Bun;1007063 said:If you are going to replace the water pump, take the opportunity to check the hoses and fill it up with distilled water.
tomace;1007089 said:So TS, any update?
This happens to my E90 320i before & it is mechatronic faulty, position sensor faulty.
MA only tow & did reprograming nia ~~
PML replace both on next warranty repair..
Hope yurs all smooth sailing ~~ Cheers
ac323;1007105 said:under warranty Rocks..........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
wt_know;1007120 said:bang table shioks .......................
vexxus;1007095 said:
Thanks bro.
As per mentioned, no. 4 & 5 ignition coil down liao, now waiting to have it replaced.
Will update feedback upon replacement.
Cheers.
ac323;1007379 said:so far i've not reach the bang table stage..........
pohls;1007473 said:i had a similar experience, but with additional symptom - transmission error icon lights up. Ended up need to change the valve body assembly, costing $2,800.
E90 - 2006 323i
seanskye;1007027 said:Engine mounting?
