What Spark Plugs for E60 525
Re: What Spark Plugs for E60 525
vypez;929451 said:
bro, change.
logical thinking tells you to. they claim its lifetime oil, but common sense tells you its not possible.
$3xx for peace of mind VS $8000 if gearbox kaput. you weigh it up.
Agreed, did a ATF change two months back.... :)
Hi Guys,
Any comment on normal mileage for spark plug change? I am getting 2 diff info from diff PML S.A.
Did my 53K servicing, was told next change shld be 100K.
Doing my 63K now, was asked to change....cost about 250...
When was your last spark plug change ?
yegh55;1068972 said:
Hi Guys,
I replace my e60 plugs with bosch iridium once i received it. After 10k mileage, i remove plug coils and inspect found that 5 out of 6 was leaked at ceramic side. 1 of them more worst, ceramic was broken. I suspect it was quality issue.
Replace with Denso iridium 6@$150, then and still going strong for 15k mileage already. My workshop mechanic advise me to replacement with correct specs more important than replacement plugs with fancy name and ads which claim can improve fc and power. If u like those thing, install a flame thrower more ideal, guarantee best combustion .
I took over the car Feb 2013 from PPSl mileage was 45K. Was told spark plug was changed.....
The cost for my spark plug changed yesterday was $236 + Labour $122............
I think changing the spark plugs with a site sponsor would be good in your case ..... If the plugs are fouled during a check then it should be changed - mileage is another thing.
stand to be corrected:
( BMW E60 525i '06 - 07)
Bosch FR-7-NPP-332
NGK PLZFR6A-11S (5987)
Thanks Guys! Feel like being robbed.....together with Air Filter and Spark Plug...cost $477...........
Bosch FR-7-NPP-332
no lah brudder, everyone has own perspective...
got a friend die die go pml, nvr even change own wiper b4..
I diy few stuff cos I like n I cheapo bravo..
& every ws got their own business model / concept / costing.. so, to each his own
Hi Kyeong,
Agree with your opinion for diff individuals.
I was actually only going there for normal servicing (FOC for 3 oil svs). Was caught when he told me shld change both items.
Learnt my lesson once will do....shld read more from this forum and change parts elsewhere.
Nope, you are carrot meant to be carroted.
yegh55;1069306 said:
Hi Kyeong,
oki lah brudder, I also sometimes will kena caught in such situation.
my suggestion is to stick to one workshop, its business. Observe their technical works and build relationship... (oki at least it works for me)
like we all know... its business bro. cheers.
Hi bros, I need to change all 6 spark plugs + all 6 ignition coils for my e60 525, may I know what a reasonable price should be ( in PML) ? thanks !
... I was quoted almost like 1.5k ! Shocked, even for PML standard. I thought he made a mistake. Can any one who has done similar job share his cost figure ? ( I honestly think the technician I spoke to mis read from his computer? It can't be more than a couple of hundreds )
If u DIY, its only S$300...
PML i dunno...
Go ws like CodeWerx.. they do check ur coil/plugs stats after installing and also can do overall diagnostic... and should be lower cost than PML...
Thanks . That sounds much more reasonable. And PML price is ridiculous. 2x is still within expectation, 4x is way off.
i will try to contact codewerx...
pg88comim
