Whats the capacity in litres does a E46 has?
benikoh
Dudes,
just checking whats the max litres does my E46 has?
50 litres tank or 60 ?
Thanks.
Have a great week ahead.
Ben
benikoh,
it's 63 litres
Thanks a lot.
What kind of petrol do u pump?
Shell 98? full tank how much?
Thanks for the fast response.
Ben
i dun pump shell 98... i usually use esso 8000 or shell v-power. i think its ard $70-ish for 3/4 tank of esso 8000.
max I have ever filled up is 62.5L
I believe its 63L with some extra space for overflow. OBC read 0 km remaining for at least 15km. :oops:
Your da man :thumbsup:
E46,
I highly don't recommend it... I think it may kill the fuel pump (overheat). Reason I did it was that I was on NS highway and rushing back to Singapore...
Emiffy, the fuel pump does not overheat cos the fuel inside the pump cools the thing down sufficiently. What is even worse is a momentary loss of fuel pressure which will result in a "lean out" which increases combustion temperatures and in the long term causes burnt exhaust valves.
The short term problem is the fuel pump picking up all sorts of condensate and particles usually found at the very bottom.
Try not to let it happen too often..
denticoreusa
