Wheels - What's 1 KG Weight Savings Equivalent To?
Re: Wheels - What's 1 KG Weight Savings Equivalent To?
Shaun said:
The guy's analysis is right. Max is factor of 2 (mass at pure circumference moving at road speed). min 1, both exclusive.
So for every 1 kg of weight saved from each wheel, we are looking at 4 kgs saved on 4 wheels equivalent to between 4 to 8 kgs saved from body mass?
That sounds about right....
Yes for all situations where the wheels are rotating at close to road speed, then the factor is between 1.5 and 1.8 for practically all types of wheels and tires. To narrow it further with a specific wheel-tire combination, run the trifilar pendulum test I described earlier, or even a normal pendulum test.
Separately, wheel stiffness is the other factor that has to be thought about for track application esp with better tires. No point being ultra light when you lose camber through wheel deflection.
What's wheel deflection? Flex?
snowdog said:
More maths... Arrrrgh...
No choice. Cause many drivers claimed wheel's weight is so important and what not......
Now I know that even if my wheels are each 2 kgs lighter than Sam's, I still cannot beat him to the weight-reduction ratio.
Must mod driver liao.......
Thats why. U should use my HRE rims
Haighh...from a factor of 6.5 becomes 1.5 !!!! WT$
yes flex..
i think the higher ratios of wheel-to-sprung-mass equivalency came from people making assumptions after seeing calculations for rotating masses like the flywheel, etc. and applying it to the wheels as well when they are separate things. Wheels are different because they do not rotate at different speeds vs road speed. Wheel speed for all situations outside of launch tire slip, shift tire slip, and braking tire slip, is fixed to road speed.
toto and I hv been saying to you all these while to stop your addiction on Carl's Junior Burgers...gong buay thia....
Okay, will switch to MacDonald's Mega Mac soon.....
Then it makes no sense to switch to lighter rims for 1 kg weight savings but add a 10 kg sub-woofer and 2 amps behind the trunk........
Need to compensate with stuff like this:
Then someone will raise another question on 50-50 weight distribution.....
Push your seat further back and wear platform shoes......
And don't wear an underwear...
Well while overall weight maybe more with all those ICE set ups, that is static weight increase and it's sprung as opposed to reduction in real un-sprung weight and rotational mass which IMO, give more satisfactory gains for driving enjoyment in terms of acceleration, deceleration and general handling.
i feel my car faster after playing futsal....
So now you are saying 1kg reduction on the unsprung weight and rotational mass is better ("more satisfactory gains....") than X kg reduction on overall sprung weight, even though 1 kg reduction in wheel weight savings can bring about the same effect as X kg of overall weight reduction?
Hiadees,
Anti roll bar = sprung or unsprung ?
Ahbengdriver said:
Hiadees, Anti roll bar = sprung or unsprung ?
Unsprung weightmoves when the wheel moves. “Sprung weightmoves when the chassis moves. So, you say leh?
pg88comim
