Eng Soon...clar;796767 said:Anybody knows where I can cash and carry Castrol oil for our M3?
davidtch;796783 said:Eng Soon...
I saw sometime back in ES TWS 10-60 for ///M3. Maybe u call up & look for Pauline.clar;796842 said:Just called them. Bo leh. The fella said they don't carry Castrol.
davidtch;796848 said:I saw sometime back in ES TWS 10-60 for ///M3. Maybe u call up & look for Pauline.
TohTo;798160 said:You can try MXTradings. They should have Castrol Edge with Syntec .
S2k;805291 said:+1 i got my castrol from them as well
turbocharged;805366 said:Which weight are you using? 0w30?
For BMW, u can't use Castrol Edge with SPT because it is not LL-01FE/LL-04 compliance.turbocharged;805407 said:Think better just keep to Castrol Edge with SPT 0w30 to be on the safe side Its made in Germany with an European formulation. Maybe after my engine has over 10k clocked, I will switch to an esters-based oil like Redline/Motul.
davidtch;805560 said:For BMW, u can't use Castrol Edge with SPT because it is not LL-01FE/LL-04 compliance.
U should look for Mobil 1 ESP 5-30.
The biggest diff is HTHS (HI Temp Hi Shear) value.
