Which tyre to change
Re: Which tyre to change
used before the michlin ps2..its very good :thumbsup: ...standard m3 use this tyre too.quiet also!
johnhiggin said:
Hi, all
About to change my rubber. Currently using 215/45/17
Which do you recommend for high performance tyre below?
i) michelin PS2
ii) Goodyear Eagle F1
iii) bridgestone SO3 or RE750
iv) any other good recommendation (performance tyre and also not noisy)
Would appreciate your view.
johnhiggin said:
Hi, all
i) michelin PS2
how about the advan nova range? any comments on those tyres?
johnhiggin said:
Hi, all
i) michelin PS2
johnhiggin said:
Hi, All
Can also advise the price S$ per tyre?
ES100 is which brand
Last I checked about 3 months ago, Michelin PS2 around $330/pc 225/45/17 and SO3 around $270/pc.
PS2 gets my vote. It is suprisingly light in weight compared to SO3 and grips well in both dry and wet. Handling is nice and progressive, lots of feedback, lets you know when your tail is about to go out. I can't comment on SO3 handling cos I haven't tried it personally.
blackacs said:
johnhiggin said:
Hi, all
i) michelin PS2
Are you referring to the AD07?
johnhiggin said:
Hi, all
i) michelin PS2
You could try P-Zero Nero or Rosso, should be about $290 a piece. Another tire worth considering will be Bridgestone REO50A, about $290 a piece too. As for the ES100, I had it on my previous ride, best to avoid it if you are serious tracker/street driver :evil: . I brought it to PG and the tire cannot last more than 2/3 laps.............and it aqua plan quite badly at the speed of about 80km/h after running about 8000km on it.
Cheers!
8)
hi, Vanquish
Ask ard about Eagle F1 GS-D3 but no stock, $210/pc
similar range to PS2 but 50% cheaper compare to PS2.
Any place to buy?
Rather pay more to buy a better tyre than regret for next 2 years.
BMW.......liao (Broke my wallet)
Isn't that run-flat tyre? Have that on my ride.
Why no mention of the Toyo T1-S tyre? They were pretty popular amongst the tracking crowd in Canada.
hi
bfgoodrich only $140 bro
michelin ps2 is at $310
POH HENG TYRES
98368640
amk ave 10 blk 4002
i hope this pricing helps thanx :)
johnhiggin said:
hi, Vanquish
Any place to buy?
I got mine at Tai Huat last month. Think they should still have them in stock. Mine was 225/45/17. Go check it out? :)
Tai Huat
246P Upper Thomsom Road
Tel: 64537205
I don;t think so, just check with Hurry Tire, there say not run-flat but a replacement for RE040. There is also a runflat with similar model name.
Cheers!
8)
Hi, all
Just changed my rubber to GSD3 on Sat as they got 215/45/17
PS2 no stock got to wait.
Also, $ PS2 cost 50% more than GSD3.
Seems quiet but can't confirm as the tyres still very new. Had to run in for mabybe 5K km at least.
sawer13login
