Classifieds Rules
3. Provide clear contact instructions (List phone number, email or PM). *
1. No OT. They will be deleted. If you
continue despite us warning you, we will ban you from the classifieds completely.
DreamDriver said:opvaulet said:.. some people just fit original M3 bars (apparently similar price)..
Wah, can M3 bars fit sedan? If so, what sizes are those?
Jack: *hint* *hint*
Racebred said:I'm not sure if M3 ARB can fit non-M. I have a feeling they dont, as the track and the shocks mounting points are slightly offset. The front ARB is attached via ARB links attached to the front shocks. If you upgrade to KW coilovers they give you a shorter link to replace the original one. The rears are attached directly to a mount on the rear shocks, joined by a bushing.
I did a google on sway bar.SL2 said:Can anybody please advise me what a sway bar is and what it can do for your ride? Paiseh hor...I'm vehicle parts illiterate!
The Mixmaster said:Pak Jack
Why is it that a stiffer setting of the FRONT ARB will increase Understeer while the softer one will increase Oversteer?
Also, can you help me to find an ARB for my W211? Thanks
ryan said:I did a google on sway bar.SL2 said:Can anybody please advise me what a sway bar is and what it can do for your ride? Paiseh hor...I'm vehicle parts illiterate!
http://www.carcarecouncil.org/Steering_Suspension/sway_bar.shtml
Description: The sway bar, also known as a stabilizer bar, is made of spring steel and mounts to the frame or unibody. The ends of the sway bar connect to the lower control arms.
Purpose: The sway bar helps reduce vehicle lean during cornering.
Hey dude, no prob. I'll drop Whiteline a fax and let you know in the coming week yea!opvaulet said:Hi rex7 vtec,
i would like to enquire if whiteline do a 17mm rear bar for my e34. my originals are 15mm.
Thks!
