wiper jet not working
bodvista
hi guys,
currently driving 5yr old 320i.
having some issues with my wiper jet. when i pull back the wiper indicator towards me, wiper spray doesnt pump the water to windscreen and also no wiper movement.
if i just flick the indicator up or down, the wiper will move as per normal.
tried filling up the wiper jet reservoir with abt 2L of water but still not working.
has this happened to anyone? where can i get this fix?
any workshops that opened til 7pm on weekdays?
thank you alll gurus in advance.
Re: wiper jet not working
I think if you ask about mods, gurus will point the way but if it is about things broken, best go straight to workshops.
my wipers are mal-functioning on raining days.
Ie either doesn't operate or get jammed. Brought it to workshop but everytime diagnosed as okie.
Anyone can help? or recommend a workshop where i can fix this problem?
my problem was due to faulty wiper pump... changed at BMworkshop for 50+20(labour)
problem solved.
what is your problem exactly? wiper not moving? try bringing to BMworkshop for diagnosis
I sent to one of the workshops at Sin Ming and the technician did not mention if its pump failure.
The fault lamps for wipers keep on appearing and sometimes I just need to restart my car and the fault will clear.
I probably be sending to another workshop for their opinion.
super high chance your wiper motor postion switch has gone up to heaven. The bad news is that the entire wiper rack will need to be replaced. A GT-1 or equivalent to see the error code will reveal the gremlin.
good luck
boskiogutjp
