WTS: E46 M3 Brake Calipers and Rotors - Front and Rear
Re: WTS: E46 M3 Brake Calipers and Rotors - Front and Rear
i've posted the pix in another thread, but here it is again.
pics of the M3 brakes taken off my car.
this is one of the rotors (fronts are 325mm and rears are 328mm). still quite thick.
notice the 2-piece design - aids cooling, less heavy than the one piece ones too.
cross-drilled and ventilated.
don't have to skim as they were working perfectly on my car - no judder, not warped.
pic of all 4 calipers and carriers. all stripped and painted before reassembly.
close-up of the caliper pistons - no rust, and the rubber boots in good condition.
also includes the stock rubber hoses, which i would recommend changing to steel-braided ones if you are to maximise the efficacy of the mod.
have not taken any pictures of the stock pads, which you can still use.
selling the whole set for $2.5k (which is cheap considering the cost if you get this from Eng Soon).
you can drop me a line at 90496178.
cheers!
bump for national day!
considering for an E46 318i...servicing due soon...how much approximately to do service at R2D?
depends on what you need to do...
normal servicing - changing engine oil, air filter, top up brake fluid - cheap cheap.
but then it also depends on what kind of engine oil you're using.
on top of it, you're getting TLC from the resident e46 doc...
okiez hope for good news :)
waiting to hear from you :)
R2D off bukit batok
bump for a slow, boring friday...
ok365ok365com
