FiftyFive;241014 said:With coilovers, there are a variety you can choose from.. from affordable to those which are slightly more expensive... trust me... you get what you pay for...
From BCs, Teins, Bilstein PSS (Height Adjustable only-no Damping adjustment), Bilstein PSS9, KW Variant 2, Variant 3, KW Clubsport & Ground Control etc etc... A whole range of coilovers to suit your demands and needs... are they for show purposes or are you planning to track your ride as they all pretty much give u better handling... comfort is another story all together.
What is important is that you do your homework properly... be firm on what you want your coilovers to do and then go get them... you will end up better off and might even save some money... Dont fall in the trap of buying something just because your wheels are here... patience is the key..
With regards to rolling of fenders... nothing is impossible... once you have determined your wheels and suspension (coilovers) setup... if they rub... you go roll them... if they dont... good on ya... given the configurations that you have supplied above in the thread... I forsee minimal rubbing subjective to your ride height... otherwise you will probably jus have to roll a bit to be safe...
Hope this helps... happy shopping...
the one guru;241024 said:mwtang,
are you in KL? did you buy over the net? were they taxed?
Azrielsc;240974 said:Hey mwtang.... that photo that u have in ur avatar was my ex-car! HAHAHAHAHA!
mwtang;241130 said:Bro, thanks for the lengthy advise, i am already on koni FSD + eibach springs. What would u recommend for alternatives to eibach as i tend to find it soft.
VenomX2;241402 said:Comparing Bilstein and BCs would Bilstein be comfy and not harsh?
Ahbengdriver;241404 said:U see, this is what I always get cunt-fused.
I hear peep-per say "Coilovers are harder or stiffer than springs/koni, which is more comfy". Then I also hear "Coilovers can be adjusted to achieve comfort but even the most comfy setting is still stiff".
Now I hear something new "Coilovers give u a harder ride but is not harsh"
FiftyFive;241368 said:CBS was/used to be on the set up... he loved it intially... until he sat in coilovered cars... haha
kenntona;241971 said:Just a question - is there any harm rolling fenders, even if it does not rub?
Beng, +25 rear is quite aggressive.......Ahbengdriver said:Hiadees,
the E92 OEM offset is +35 F/+30 R.
If I put on rims that have +30 F/+25 R to push the wheel flusher, will there be rubbing or do I need fender rolling?
