Aircon question
chriz
My BMW 318 has 1 more year to go before scrap.
Aircon sometimes not cold when stationary on sunny day. When on the move the aircon is cold. Most of the times it's ok.
I was told must change the cooling coil abt $680.
Shld I just top up gas OR change the cooling coil?
Pls advise me. Tks!
Re: Aircon question
just drive with windows down la.
Raining time, use portable fan
Left one year, no need to spend money..
Re: Aircon question
unless COE drops to S$888.88
Re: Aircon question
I think topup gas is good enough since aircon is still cold most of the time.
Unless aircon is warm air only then change the cooling coil.
Re: Aircon question
u asked and answered ur own question!
Fastest thread I have ever come across.
Re: Aircon question
My answer was based on yr response.
It seems logical what you said...
Re: Aircon question
Then you must click "thanks" to the wise one.
Re: Aircon question
His creative way to make u think and come up with the answer ;)
Re: Aircon question
Red_Bean_Bun;1001708 said:
Don't think cooling coil issue .....
Most pple & the workshop says its cooling coil.
But I decided to topup aircon gas one time & monitor 1st.
Re: Aircon question
Maybe fan issues. Or compressor / belt issues. Cooling coil dirty issues.
Gas pressure issues also possible (easiest to eliminate).
Re: Aircon question
go for flushing.. it certainly helps and with the right diagnostic, it can determine if gas is over or below level. I used to had so much problem with aircon with my previous ride till i found a very good shop that rectified all the problem and most importantly save $$$. let me know if you need the address of the workshop. it's in Jurong though
Re: Aircon question
Based on the description of the symptoms, i.e. warm when stationary, cool when moving, my guess it's unlikely to be the cooling coil, more likely the aircon compressor.
Re: Aircon question
Ya lo, go buy those usb powered fans, I think really not worth to change,
Unless
Buy coil fix, before scrap change and scrap, sell cooling coil to some guy who got his coil leaked
Re: Aircon question
Hi I THANKS your valuable contribution to this forum and to your wise suggestion for TS to THANKS me.
But please don't report me. I scared kenna banned again n cannot come in to THANKS you
Re: Aircon question
Hi wise mwan.
Sound cynical?
Re: Aircon question
Hi REND,
Could you kindly share the contact of your workshop with me cos I've an AC issue with my 8 years old BMW 320i recently and don't know who to approach. Thanks!
Re: Aircon question
dolphinne;1002209 said:
Hi REND,
Bro I have sent you a pm. Pls check.
Re: Aircon question
$600+ is a good cost. Air conditioning is not just about cold or not cold.
If I am not wrong, if your cooling coil breaks down, still ok. But if it is the compressor, you probably get a damn bad smell....
And you probably want to think what you are breathing in.
Not an expert, but I have repaired air con for 3 cars previously and currently own.
shipsandsciencecom
