Red_Bean_Bun
Re: Any Battery brands to recommend?
CCA is an important spec to follow. It cannot be ignored.
roberttan;1048755 said:base on above prices , outside price is sure lower (but not cheap)
AH is the 1 to lookup for , uses the same or slightly lower or higher is fine.
to me don't need to bother so much about the Cranking CA or CCA , because our climate doesn't really affect the Battery performance , those CA or CCA are usually for COld climate.
remember all those battery need a vent hole at the top side of the battery and just be sure the vent hole are connected and the other hole is ----CLOSED---- or block
