Ap racing brake kit.
Re: Ap racing brake kit.
jerms;897371 said:
I thought u already got bbk????
got BBK, next ride i meant.....
cheeeeeeeeeeeeeeeeeeeers
rexis;891055 said:
Here are the promotional pictures taken at Merlin.
I think one of the reason is also because of the OEM
rotors. I've been down there personally and saw the
brakes. So if u guys are interested wouldn't harm if
u go down and take a look. Its a big investment, so
must check properly.
FYI !!!
Ori AP Racing rotors only have 356mm And Caliper model : CP5575
This must be mix & match set. No such things like OEM make.
I saw a set of 100% fake items within red col with full AP inprint, with the additional rotation's stickers on the calipers....
Correct me if I'm wrong....
Do take note that each ori AP parts ( Caliper, center hat, rotor, bracket etc etc...) should have their parts numbers engraved on.
wt_know;890785 said:
$2900 for AP Racing 6pot brake kit ??? u nia boh???
Where got so cheap? I also wanna get wor.... Where is the lobang?
Hi bro,
I got this from a friend who is buying from this bro. Below is the description
Hi Bro!
Thanks for your interest. Alcon mono six full set is $4999. Brembo 18Z and Stop tech full set $4499
Aiming to penetrate market and gain market share before motorsports is heated up by a potential local track, I am offering a Blow out discount on all kits and lol, this means very very little margin for this promotion.
For a limited time to make it the promo unresistable, limited time only while stock last. We will be offering an extra set of mintex 700 degree front pad for the purchased bbk. This alone is almost $300 in value.
Importing direct from an Authorized UK distributor and selling direct means less middle man cut. Getting in larger volume also means lower freight cost and yes, I supply to the Rex and Evo community as well.
For the AP set, we have Full set and mixed set. For the mixed set, all parts are supplied by the same uk distributor, make by an UK machining firm, Delta Precision (DP) who is supplying to numerous smaller house brands.
All AP calipers have a choice of red or black (I will absorb the extra cost for the Red caliper). For Alcon, only full set.
1) AP racing CP7040 6 pot Full set
$5560 now $3999
Caliper: AP CP7040
Pad : Ferodo DS2500
Rotor : AP CP4542 48V, 2-piece 355x32mm, slotted, need minimum 18" wheel with offset at least 45, depending on wheel design
Steel Brake hose: Goodridge set
2) AP racing CP7040 6 pot Mixed set
$4080 now $2999
Caliper: AP CP7040
Pad : Mintex 700 degree
Rotor : DP 2-piece 355x32mm 48 vanes, exact same specs as CP4542
Steel Brake hose: DP set
5) AP racing CP5200 4 pot mixed set
$3650 now $2699
Caliper: AP CP5200
Rotor : DP 2-piece 330x28mm 48 vanes, exact same specs as CP3580
Steel Brake hose:delta
Why get from us:
Great Prices:
Imported direct from an UK distributor and selling direct means less middle man cut. Getting in large volume means lower freight cost and yes, we supply to the Rex, Evo, VW/Audi, Saab and other communities as well.
Replacement parts:
We stock AP, Alcon and Delta replacement rotors; Mintex, AP, Ferodo, Brembo, Pagid and OEM VW/Audi pads. Goodridge and Delta Stainless Steel Brake Hose.
Warranty:
For all kits, there will be a 6 months limited warranty on factory defects but wear and tear parts not included.
Private Sale:
Once a year, we have pad and rotor promo at a subsidized price for those who purchased their kits from me and we are talking about less than $200 for a set of Ferodo DS2500 which usually retails for $300-$400 at most work shop.
Peace of mind:
We have been importing and supplying performance BBK since 2008 and have numerous references from different forums. You are free to PM our buyers for actual users feedbacks, good or bad. Talking to actual users should gather more candid, unbias feedbacks.
Others:
If the above are still not enough to convince you, do feel free to feedback to us on how we can win your business and we will accomodate if we can. Your business is important to us and we sincerely want to be part of your performance part purchase and ownership as we are fellow car enthusiasts ourselves as well.
Viewing and payment:
I have a display counter at a shop near Gombak MRT and you can drop by to view the actual set mon-sat 9am-7.30pm.
To reduce overhead and charges, all prices are cash and carry. I can accept credit card via paypal as well but you will have to bear the paypal charges of 5%.
Installation:
All prices cash and carry only. The kits can be installed in most workshop as they are direct bolt on. We do not work with any workshop so as to pass all savings to you but I can refer one as well. Brake installation is typically $90-$150 including brake fluid.
A lot of our VW/Audi bros installed our kits at a pro-VAG workshop HAT since they know your VAG car well. You can also contact HAT direct for installation pricing and even feedbacks on our kits. However, you are also free to go to your favourite regular workshop
Last but not least, We have supplied more than 50 kits to audi vw bros alone since 2008 and do have numerous references in the forum which you can PM them directly.
Проститутки Н
Проститутки Нижнего Новгорода и области, предлагают интим знакомства, для оказания секс услуг и эскорт услуги по самым сладким ценам, элитные и дешёвые проститутки только с фото и с прямыми телефонами. заказать проститутку в н.новгороде
Проститутки Н
Проститутки Нижнего Новгорода и области, предлагают интим знакомства, для оказания секс услуг и эскорт услуги по самым сладким ценам, элитные и дешёвые проститутки только с фото и с прямыми телефонами. проститутки Нижнего Новгорода
Проститутки Н
Проститутки Нижнего Новгорода и области, предлагают интим знакомства, для оказания секс услуг и эскорт услуги по самым сладким ценам, элитные и дешёвые проститутки только с фото и с прямыми телефонами. заказать проститутку г.Нижний Новгород
So is it still safe to buy?
I need to change brake asap.... May be getting OEM brake. But not sure how much? Reason is becoz i dont think i will be driving for long as i hope to change car soon.....
So far nothing from this topic? I have changed car already... But wasted money on original brake rotors and pads and drive for 400km before selling off my car... Now my new car needs BBK..........
if you are taking your car to the track and running R rated tyres then spend the $$ otherwise save it.... probably not worth it.
which variant you bought?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
gemwinrestauranteclubcolo
