Best semi-slick?
Re: Best semi-slick?
totoseow;628696 said:
i sux with kart really. cant fit the sititng positions no matter how i try. back aches all the time. short people syndrome.
adjust the kart to fit you, not the other way round :thumbsup:
i stick to cars for the moment. no time for another hobby. besides im too scared in karts. not sure im cut out for it.
changi one not promising, think u stick to street racing better
MachoMan;626186 said:
So how do we go about finding out what's the optimum tire pressure for our car's weight? The australian yokohama website said 36-37 PSI for the A048 too, and I find that pressure too high.
All roadcar tire manufacturer pressure recommendations are only ballpark +/- a few psi and they're usually cold or barely warm pressures, certainly not hot.
Only the more performance oriented tires have a recommended hot pressure and the tire manufacturer still doesn't know everything about the car that the tires are mounted on. You have to find your own optimal within the ballpark. Driver must already be ballpark good. Run a bunch of laps, varying pressure either side of recommended hot pressure. Put markers on your tires, look at onboard video or photos of your car on track to see how much the tire is rolling. Look at your lateral and longitudinal accelerations, feel out the stability of the tire, check that wear is ok. As long as you're not under 90% of recommended hot pressure (if any) and the performance indicators are maxed within reasonable pressure window, with no crazy rolling of the tire under lateral load, or weird long term wear, then that's 'optimal'.
For many factors there are is no optimal, no easy answer, have to realize it all functions as a system and test. And not just guess and go by memory, but have a plan, follow it, measure, make records. Data..
MachoMan;628751 said:
These karts can to 140km/h??
Single speeds geared high enough can. 6 speed shifter karts can go 0-160-0 in under 10 seconds, 0-100 under 3 sec.
They don't have a safety cage around the cockpit. What if another kart crash onto you? Is flipping over common in karting? I've seen some horrible kart accidents. One kart on top of the other type.
That's why you have full suits, rib guards, neck guards, which help a bit. You still don't want to crash though. Have to be respectful of other drivers and not just lean and push your way around.. else it could be you flipping. It's good in the sense there is a real potential penalty to pay for being reckless or imprecise.
See video below.. the karts look light but they're roughly 80-95kg flying around. 170-190kg with driver, depending on class...
[ame="http://www.youtube.com/watch?v=IB8Flty3yzU&feature=related"]YouTube - Kart crash compilation[/ame]
Also curiously, do these kart have LSD? If not, why? What about those F3 formula cars? I'm bringing this thread off topic again. Hehe
Karts have no differential. Keeps weight, complexity, and cost down. Free up the inside wheel by unloading it with weight jacking via lots of caster and scrub radius.
F3 cars have diffs. Cars are not designed to jack so much weight. If they had so much caster and scrub radius, it would take a lot of power to turn the steering wheel.
Can't generate the loads that karting does without million dollar operations and racecars (F3 or higher, GT1 or SGT, LMP at certain tracks). It's why F1 drivers train in karts in the off season. If not for the average dumb consumer, the companies chasing after their dollars, and the misguided culture it's grown for decades; most everyone would be karting, few to none would be driving cars around on tracks.
Those kart crashes look sick Shaun....
Duno to laugh or what...
Fkin mental if u ask me...
i think its scary. i hoot a tire wall b4 at 60kmh. i think.....sprained my fingers.
Local track KF2 karts reach peak speeds of only about 100 km/h. Rotax a little less, KF1 a little more. For higher speeds at bigger tracks / tracks that allow shifter karts, have to go into Malaysia or wait for Changi.
Also most incidents occur in wheel to wheel racing, so running solo and not pushing limits, the risks are much lower.
Fav part of the video is from 2:36 to 2:43. The poor dude is being efficient, using literally every last inch or track width, high frequency low amplitude steering corrections, hauling ass through the sweeper....... and then can't avoid the guy who has spun out and parked on the track... man what bad luck.
Shaun: you've been making a lot of good arguments for people to try karting... but one look at the video is all it takes to reverse that!
If one were to make a compilation of all the worst car crashes around, people watching would be scared too. But those who have seen the typical open trackday, and even the typical touring, GT car, LMP car race, will know that those incidents are rare and mostly avoidable if the drivers decide not to push it.
Which is why you should kart more to see that it's not as crazy as it seems. The learning curve is steeper than in cars, but once past the first month or two usually everyone is nicely settled in by then.
Have to be logical about it mate :D
Wilco. Out :D
JW, don't be a puss.
Even 12 year old girls kart. And they are fast, and still alive after all this time.
[ame=http://www.youtube.com/watch?v=iNkZcbWWUtA]YouTube - SKC - Feature on female drivers Gabriella Teo and Manon Maistre[/ame]
ermmm dun mindme 2 cent...i never even drive sepang before hehe
direzza 03g? saw it once at my fren shop...goggle search says its great?
hi guys
need recommendations for my ride. currently using toyo semi slicks
Remember these girls? They did battle just last weekend :D
And yes they're all fine, and still fast, having fun.
