BMW F82 M4 came in to fix all its outstanding issues. We are happy to make sure the ride is back to good health again!
Thank you for the trust & support!
BMW F82 M4 Competition came in to lower his ride. We recommended BMW MPerformance HAS kit. The amount of engineering BMW MPerformance team spent perfecting this is enormous!
This kit not just allow adjustment to the height but also improves the ride quality temedously!
Thank you for the support!
BMW F80 M3 belonging to our very close friend came in to upgrade cooling system.
1. CSF Front Heat Exchanger
2. CSF Top Mounted Charge Air Cooler
Thank you for the support buddy!
BMW F82 M4 came in to install his TracTive Coilovers with EDC.
We made sure that all are fitted properly with proper tools. We also made sure that all screws are installed correctly with correct torque and correct method.
We were happy with the installation. Hope our friend enjoys the dedication our crews put in.
Thank you for the trust and support!
BMW F82 M4 came in to replace a faulty sensor. We were certain that it is that particular sensor. True enough, we sorted the issue.
With the experience, we are able pin point the fault. None the less, we have to appreciate the trust given by the owner.
BMW F80 M3 came in for some repairs. We were able to also find issues that can be catastrophic.
Every car that enters our workshop, we will make sure that things are properly done. It is our profession and we take pride in all our works.
Thanks to our team, we were able to get it up and running. It is not just hard work but also skill and experience that money cannot buy.
BMW F80 M3 came in to fix oil leakage. We are honoured to be able to work with this precious belonging to the founding committee member of M Club Singapore.
BMW F82 M4 came in with air-conditioning issues. We found out that there was a leak at the cooling coil.
It took us 2 days to finish the works. Thank you for the support!
