BMW F82 M4 came in to replace cooling coil. We had just top up the freon abt 3mths back and it has again drop below minimum.
It is a tedious process and we had to do it well and right. Thank you for the support!
BMW F80 M3 came into replace rotors. We also advised our friend to use Endless MX72 brake pads for better track performance.
MX72 not just increases the braking performance due to its higher temperature range, it also reduces brake dust by a ton.....
BMW F80 M3 Competition came in to do some upgrading for @assureinsurance Track Day EP3.
We upgraded the crankhub with @gintani 1-Piece Crankhub. We opted for Endless MX72 Brake Pads & Endless RF-650 Brake Fluid.
Now it's time to push and enjoy
BMW F80 M3 belonging to the grandfather of @bmwmclubsg came in for some works.
We changed the following items
1. BMW Expansion Tank
2. FTP Charge Pipe & J Pipe (Aluminium)
3. BMC Drop In Filters
4. DCT Filter & Fluid Change
Thank you for the support! Always good to see you!
BMW F80 M3 came in to replace a damaged oil cooler & some other components.
Luckily the parts were readily available. And we replace them. Thank you for the support!
BMW F80 M3 came in to install BMW Carbon Ceramic Brakes with Coding.
We also recommended owner to use Endless RF-650 Racing Brake Fluid.
BMW F87 M2 came in to upgrade his exhaust.
We recommended Akrapovic Full Titanium Exhaust with Carbon Fiber Tips. It just improve sound but also power. And yes, it is so much lighter!
BMW F80 M3 came in to work on his valve seals. We were able to have enough time to work on the car and took the opportunity to replace his valve seals and fuel injectors.
BMW F82 M4 Competition came in for some power mods. We also took the opportunity to flash his car with Bootmod3 Stage 1 Tune.
Owner come back next week for another mod. Stay tune!
BMW F82 M4 Competition came in to upgrade his brakes. Owner opted for BMW Carbon Ceramic Brakes which is a factory option retrofit.
Thank you for the support! Now can chiong b road like a king.
