Nice to know from a user.kenntona;978782 said:..... BTW, the Sonax Coating is good.
kenntona;978782 said:(1) Change brake pads to low-dust pads
(2) Change to BBK
N54toN47 said:Will 1 void warranty?
kenntona;979169 said:Might.
But that also defines MODIFICATION and TRANSFORMATION.
Changing emblems and putting an M-badge is not modding.
N54toN47;979174 said:Yeah, i was kindda worried about that. Lol yes changing emblems and putting an M-badge is not modding. However, you could be accused of being delusional.
Shev;979178 said:U could buy Kenn a good lunch and ask him show u his ride. Then u will understand wat is call MODIFiCATION and TRANSFORMATION!
And u will also realize he is Internet hero...
*run away*
Internet Hero = Real Life Zero = Keyboard Warrior = Real Life No Balls = whatever u can think off from here onwards.....N54toN47;979179 said:internet hero is simi?
Baby1M;979209 said:Internet Hero = Real Life Zero = Keyboard Warrior = Real Life No Balls = whatever u can think off from here onwards.....
No worries. I am kidding but more importantly I was referring only the the term, not the personN54toN47;979215 said:hilarious :laughing:
he sounds very nice and helpful i'm sure you're just kidding around
I now double confirm what Kenntona stated i.e. The SONAX Xtreme Wheel Rim Coating NanoPro is so much better than the Armorall Wheel Rim Sealant.kenntona;978782 said:... BTW, the Sonax Coating is good.
Baby1M;979309 said:I now double confirm what Kenntona stated i.e. The SONAX Xtreme Wheel Rim Coating NanoPro is so much better than the Armorall Wheel Rim Sealant.
I applied it twice* on all 4 rims today, looks like it can still be used for another 5x... but seriously I have no idea.MTechnic;979370 said:Bro,
I just bought and collected the Sonax extreme wheel, rim coating ....
Hope it's good man ..
But do I need to spray on the entire wheel?
Seems per can spray 3 times ? Unless I have sprayed too much
Is it the carbon ceramic or does it have higher temperature tolerance? Otherwise the brake pad's effectiveness could be essentially the same as those supplied by BMW. IMHO.leonardlp;979414 said:Using ebc yellow
Veri good braking power but squeaky n very dusty
Just help me avoid a headon collision today. Prob up lorry alr if not for ebc n bbk
Stock brakes suck big time
Baby1M;979411 said:I applied it twice* on all 4 rims today, looks like it can still be used for another 5x... but seriously I have no idea.
Yes, u have to spray** on the entire rim (rim must be washed and clean dry). As advised by the 'direction of application', the following steps;
1) spray on front rim then use a cloth to spread the coating (personal preference, front wheels first)
2) repeat it for 2nd rim.
3) back to 1st and use cloth to 'polish' it.
4) repeat step-3 on 2nd rim.
5) repeat step-1 to 4 for the rear rim.
6) and u r done.
* I repeated the above steps twice i.e. 2 coats
** do not spray too thickly, just with TLC![]()
MTechnic;979422 said:Ah... Alright
I think I sprayed too thick .
Shall try doing it twice...thanks ya
