Brake Vacuum Pump repair for E90
Derrrick Yap
Hi Guys,
Should your brake vacuum pump needed to be repaired due to leaking. You can now got to MUNICH and get it done as they carry e repair kit.
Damage$$ = 3 Blue pcs with some change return.
Re: Brake Vacuum Pump repair for E90
Derrrick Yap;745019 said:
Hi Guys,
Hi DY,
noted...........................
Any tell tale sign indicating when your brake pump going to up lorry bro?
TIA...
You can smell oil burning smell if there is a leak as it will drip sown to the exos pipe
Hi
think my E90 have this problem....
The brake will sometime be very hard to depress in order to start the engine. Once started it become soft to normal liao.
And i do sometime experience some burnt smell coming fr my air-con..... So my vacuum pump leaking?
Cochran;926830 said:
Hi
check if you have any oil stains on your engine block as what i had in the pic below. apparently it's very common for leaks to occur on the engine rocker cover gasket and/or vacumn pump for our N46 engines. for my case, the rocker cover gasket was replace once for valvetronic motor replacement but leak occurred again. vacuum pump was then replaced and this seem to have solved the problem.
Hi Guys,
Hmmm thanks for the Info..... I just called Munich but the mentioned no repair kit.... and I have to replace the whole assembly.... may I have the contact to your sales personal? maybe they have it then, but not now? Do advice, thanks.
cos they quote me 44pcs of Blue Notes hahahah and I flipped......
smell small ting... i saw smoke from bonnet... LOL
Have you considered getting a second opinion with other site sponsors ?
Just replaced mine. Vacuum pump generates vacuum for more systems than just the brake booster. I guess it may be possible to just replace the oil seal (?), that would be cheaper, but local ws may not be willing and recommend replacing the whole pump, still not that exp.
A reliable workshop should advise the correctly. If the vacuum pump is working well, why replace it? Mine only replaced seals as the pump was working well.
Bro can you pm me the workshop ? I think i might have some problem with the pump and and the seal could be the culprit instead of replacing the whole vacuum pump
Hmm... how do you know it's the vacuum pump? The telltale signs of a leak will be a small fifty cent coin pool of oil collected all the way at the back of the drip tray (just above the exhaust manifold).
Nonetheless, get it checked out properly by an expert. Self diagnosis usually leads to more issues. You can find any of our site sponsor workshops. I did mine at R2D.
I think if you tell XMMs that they would be very impressed also ......
I'm just pian chia one. You are the real Tech Guru!
I still think compare apple to apple. Go pml check. Confirm Munich far far away from pml for our 3 series ...
If outside workshop then compare a couple of workshops to decide.
I just run thru all my receipts I notice how stupid I was earlier on just believing what Munich says.
Even their express service is still more expensive to pml servicing plus checks.
Your brake vacuum also got problem ?
I think hardened brake pedal before engine start is an early sign for pump so pls fix immediately else may lead to booster damage which much more costlier. I learn it the expensive way.
pastoraleflower
