I have the understanding that the front suspension on the E92 335 is almost identical with the E92 M3, as well as, 90% of the rear suspension. Is it true that one can literally bolt on an M3 suspension and brakes on an E92 - and that the only real difference between between e92 335 and e92 M3 is the rear track width + LSD?
So assuming LSD and a good set of coilovers are in place...... is the following statement correct?
"Replacing four front links (tension struts/thrust arms and wishbones/control arms), camber plates, six rear links (wishbones/control arms and guide rods), and four subframe bushings will essentially give you M car suspension feel and performance."
Any comment?
Any comment?
