Calling for all E92 and E93 owners!!!
Re: Calling for all E92 and E93 owners!!!
perhaps you can elaborate on what you mean by "handling not sporty enough". as compared to?
and the "cranky gearbox at low rpm" is perhaps because you have "reset an [sic] new adaptation" to shift up later, so at low rpms the gearbox is hunting for the right gear?
David 335;900336 said:
Hello
Recently get 335 i coupe and not happy with:
-Handling not sporty enough
-DCT gear box ,in auto mode , shifting too early even after re set an new adaptation
- Cranky gear box at low rpm
Just re sent car to pml ,now need to go for malaysia twisty road or soon to twisty road or PG track to see uf better
What are your experiences with 335 handling, DCT gear box..?
Thanks to all
thanks Jinnoi
Disapointed with its handling
- steering not accurate and some time vague, not enough road feed back trought sterring, front wheels not incisive enough.
- most crtitical to me, car can seat properly only in ecelent oad quality when cornering hard, slight no uniformity of the road make the front shoks, floating.
I have no expeience with at all with 335' e 92 and would like to know its behavior is normal because heavy car and not perfect hanling or if i may have issue with car.
fYI
I haved with presurre tyre, no much changes
I have bring car to pml:
Some rubber bush replaced ( top front shoks)
Steering pump and valve has not been checked even if requested
Need know to try it out in ..
Thanks again
David 335;900384 said:
thanks Jinnoi
fYI
Thanks again
how old is your ride? what tyres were you on? car bought from PML?
maybe suspension going up lorry?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
sharing some photos of my other poison... ICE...
sigh.. busy busy busy.... had not have the time to get it tuned yet... but anyway... pics first...
source: clarion HX-D2... still like this head unit from previous install, so went back to it...
front stage: 2-way, ground zero plutonium tweeters. had some earlier reservations abt the a-pillar, but installer was able to do it to a near-stock look... so thumbs up. had a tough choice between this and the higher range model, which was clearly better but in the end thought it is an overkill for me. the sound... is beautiful in my view...
ground zero nuclear 6.5" mid bass... this took a fair bit of measurement and discussion to decide. end result as can see is smooth and not too 'loud'... only slightly tricky thing is the passenger might sometimes not be as careful and kick the fella... grills is a must...
these are powered by ground zero reference 4 ch amp... and i must say, this is probably the soul of this setup. yes, every component plays its own part and is integral to the system, but this amp is simply a beauty...
this is the top, which one can see from the boot...
this is how it is mounted...
finally, a ground zero uranium 10" subwoofer powered by a 2 channel amp. these were the install stage photos. the final setup still needs a bit of tweaking... will upload when done... so this give some punch, but not the crazy low booms... which is a nice balance... (for now)
well that's it. simple system!
stock as stock can be....
SART..................
Power! Thanks for sharing the pix...maybe can share during meetup? :)
Calling all e92 and 93s...
hi kevin, can check with u how u get ur pre LCI headlight angeleye to be so bright and white? haha
Use sonax!
If not go to a very darkly litted area... :p
Hmm..think we have a site sponsor for Sonax products. :)
Whats your ride, kenrick?
i just gotten a second hand e93 323i 2 months back..haha
Sart..as ac would always say...roofless rocks!
coming to the month end meet up? Let us view your ride.. :)
Roooooooooooooooooooooooooooooofless Rocks...
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
You know what...lets do a stock take...Up till now, I am still alittle blurry as who owns what ride.
calling all e92 and e93..please identify your rides here
1) Kevinbmw - e92
2) C3PO - e92
3) slidingturtle - e92
4) Kenrick - e93
5)
6)
7)
please help fill in the list...i want to organise a convoy...
cool, mine is E92 minus 3.......
Organise one early morning drive....
make it 26 Oct to Sepang to look see look see.......is a BMWsg track day anyway
SapphireSpite;907692 said:
Post pics of your car kevin hahaha (cannot recall, your number plate you buy one is it?)
my pix of my car in my album. can see from there..
ya bought my plate. wanna buy? :)
Z4 lead the convoy.. :)
SART!!!!!!!!!!!!!
Now then I recall, your engine interior look so 5 series, got confused. (Your ride also look like 5 series)
Hahaha, I also recalled you got some sticker on your windscreen also and your sart sart number plate)
vn88vnxcom
