Re: Car Repair & Servicing Photo Gallery
Hi Everyone,
Another BMW F10 swing by to Revol Carz Garage with complains of oil burning smell while the engine is running. Our experience senior mechs immediately spotted the source of the oil burning smell- valve cover engine oil leakage.
Over time, valve cover gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, it will drop out from the valve cover.
The engine oil that is dripping out from the valve covers creating the engine oil burning smell.
Worn Valve cover gasket replaced and all is well now.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior.
To find out more on Revol Carz Garage servicing services or having oil leakage issue, please feel free to contact Gavin at Hp: 9740 6855
Thank you for reading!
Cheers,
Revol Carz Garage Management Team
BMW 320i at Revol Carz Garage for bumper respray and cup holder replacement
What happen when you got hit from the rear and require a bumper replacement and spray together with cup holder to replace?
Visit Revol Carz Garage to them get all done at one professional workshop!
Rear Bumper replacement and spraying in progress
Cup holder replacement in progress
New cup holder fitted
For more information on Revol Carz Garage repair services, please feel free to contact us at tel: 65551171 or SMS/whatsapp Gavin at 9740 6855.
Cheers,
BMW E93 drop by at Revol Carz garage for Bilstein's shock absorber replacement.
Bilstein's shock absorber are precision formed through a unique seamless extrusion process. This provides superior strength along with high finish tolerances that are usually associated with surgical instruments. The shock body is then treated with a special paint finish durable enough to withstand grueling 240-hour salt spray tests. The finished body is mated with a solid, induction hardened steel chrome plated and polished shaft, machined valving components and highest quality se highest quality seals. Combined with extreme attention to detail. Bilstein manufactures the closest thing to a hand built shock available today.
Bilstein's shock absorber are manufactured in Germany and have been proudly recognise as the trusted brand for BMW, Mercedes , Audi and Volkswagen.
Nothing beats the time saving to respray the front bumper while the shock absorber is being replaced.
For more information of Bilstein's shock absorber, please kindly contact us at 65551171 or SMS/ WhatsApp Gavin at 9740 6855.
Cheers,
Having the needs to top up coolant into the coolant tank?
It could be of one of the hoses or radiator pipes showing signs of leakage.
In this case for this BMW F10, a leaking hose is the cause of the problem.
Not sure if the clause of too frequent coolant top up is due to a leaking hose or pipe? Please feel free to contact us at Tel: 65551171 or SMS/WhatsApp Gavin at 9740 6855 for a free check and diagnostic with no obligation!
New Hose awaiting replacement.
Cheers,
Another F10 drop by to Revol Carz Garage for Car Battery Replacement
At Revol Carz Garage, beside a proper battery installation, we will perform a professional registration coding into your IBS to ensure the battery is properly installed.
For more information on the cost of the battery replacement, Do contact us at 6555 1171 or SMS/WhatsApp Gavin at 9740 6855.
New battery awaiting replacement .
Cheers,
Misfiring as you accelerate?
In this Bmw E90, a faulty ignition coils is the clause of the misfiring, not sure if your car jerking is due to the faulty ignition coils?
Do feel free to contact us at 65551171 or SMS/ WhatsApp Gavin at 9740 6855 for a no obligation discussion.
BMW E90 arrive at Revol Carz Garage
Ignition coils replacement
Car wash done.
To find out more on Revol Carz Garage servicing services or having oil leakage issue, please feel free to contact Gavin at Hp: 9740 6855.
Cheers,
#02-18 AMK Autopoint S568047
Garage Appointment Hotline: 6555 1171
Wishing all a Selamat Hari Raya Haji!
Best Regards,
Another BMW F10 swing by for car servicing maintenance, brake fluid and thermostat replacement
Is your brake Fluid Due for replacement?
Car Servicing at Revol Carz Garage is never simply a quick touch-and-go, oil change and filters affair.
Our standard policy is serving every car arriving at our garage with a comprehensive servicing undergoes meticulous and stringent inspection by our certified professional mechanics.
All oil leakage repair works and rectification repairs works comes with a 6 months warranty to provide car owner with peace of mind.
To find out more information of Revol Carz Garage car servicing packages, please feel free to contact us at 6555 1171 for Sms / whats app Gavin at 9740 6855 for a no obligation discussion.
New thermostat awaiting replacement
Cheers,
Another BMW F10 swing by to Revol Carz Garage for engine check light error trouble shooting.
Having engine check light and not sure what the cause is?
Do feel free to contact us at 6555 1171 for Sms / WhatsApp Gavin at 9740 6855 for a no obligation discussion.
The engine check light error symbol.
The cause of the error code- a faulty manifold sensor
Cheers,
Another BMW E60 swing by to Revol Carz Garage for car servicing maintenance and shock absorber replacement.
New shock absorber awaiting for replacement
Notice our additional services to remove the blue paint in the 1st photo?
Cheers,
Another BMW 7 series drop by at Revol Carz Garage for trouble shooting repair services.
A successful rule of maintaining a good transmission and extending the service life is that car should get a transmission fluid service replacement as per recommended millage.
An inspection is recommend to be carry immediately once you notice any fluid underneath the car.
Not sure if your car is due for auto transmission fluid replacement?
Do feel free to contact us at 6555 1171 for Sms / whats app Gavin at 9740 6855 for a no obligation discussion.
Cheers,
Another F10 swing by to Revol Carz Garage for auto transmission fluid replacement!
BMW F10 at Revol Carz F10 swing by to Revol Carz Garage for auto transmission fluid replacement
Auto transmission oil pan
Cheers,
What happen when you need to replace a bumper headlamp washer pump and respray a front bumper due to accident?
Revol Carz Makeover offers one stop professional services for you convenience with guarantee customer satisfaction.
We have another BMW X3 swinging by to Revol Carz Garage for both items to be done together!
For more information on Revol Carz Garage repair services, please feel free to contact us at 65551171 or sms/whats app Gavin at Hp: 9740 6855 for a no obligation discussion.
BMW X3 at Revol Carz Garage
Headlamp washer pump replacement in progress
Cheers,
Brake rotor and brakes pad are always replaced at a certain millage.. Proper maintenance with the correct replacement of your brake pads is deem on of the most important safety measure. With good proper brake maintenance, It can reduce the risk of accident with shorter and more effective braking distance hence reducing the risk of you and others.
Not sure if your brake pad or rotor is due for replacement? please feel free to contact us at 65551171 or sms/whats app Gavin at Hp: 9740 6855 for a no obligation discussion.
BMW 730li at Revol Carz Garage
Replacement of brake rotor and pads in progress
New brake rotor fitted in
Car wash up and ready for collection
Cheers,
We have a BMW 730li dropping by to our workshop suggesting that his car battery or alternator might need replacement as his car have no ability to start.
Upon our experience mechanic diagnostic – the clause - a broken pulley with drive belt off.
Do you know that besides a faulty alternator, a broken drive belt or pulley can also make your car loss of power without the battery charging to supply to all the electrical components?
BMW 7 series at Revol Carz Garage
Professional air con machine for proper air con gases input.
Our professional and friendly car washers ensuring all cars after repair are being washed clean before your collection!
Cheers,
What happens when all exterior oil leakage have been fixed up and yet you are topping up engine oil at every 1k? An owner refusing to follow the engine overhaul advise from other workshop, decided to seek a 2nd optional at Revol Carz garage and the outcome…. We have another happy customer.
At Revol Carz garage, we will perform various tests to determine before recommending the best option to solve your problem. In this case, millage is not too high and hence we advise and perform a valve seal replacement which solve his engine oil consummation problem at a small fraction rate as compare to a full engine overhaul!
Facing engine oil high consumption issue? Do feel free to contact us at 6555 1171 or Sms/WhatsApp Gavin at Hp: 9740 6855 with a no obligation discussion to solve your problem.
BMW E90 arriving Revol Carz Garage.
The starting process of the valve seal replacement.
Valve seals replacement in progress.
Revol Carz Garage have special tools and we uses them for special project.
Let’s take a look at the new and used valve seal.
Valve seal completed with engine compartment professionally fitted back.
Cheers,
Another BMW F10 swinging by at Revol Carz Garage for valve gasket replacement.
Do feel free to contact us at Phone: 6555 1171 or SMS and WhatsApp Gavin at Hp: 9740 6855 for more information on your car servicing services.
BMW F10 at Revol Carz garage
Valve cover gasket replacement in progress!
Cheers,
One of the more classic beauty at Revol Carz Garage for battery replacement
At Revol Carz Garage, we make sure every battery changed will be performed with profession battery registration coding on the IBS to ensure it is properly installed
For more information on battery replacement, please feel free to contact us at Phone: 6555 1171 or SMS and WhatsApp Gavin at Hp: 9740 6855 for more information on your car battery replacement rates
New battery awaiting for replacement.
Cheers,
Hi Everyone,
Still recall the black bmw which we did a gearbox overhaul? He is back for his regular car servicing. Good services keep customer back and that’s what Revol Carz Garage is good at providing!
For more information on Revol Car servicing services, please feel free to contact us at 65551171 or Sms / whatsapp Gavin at 9740 6855 for a no obligation discussion.
The return of a customer for regular car servicing.
Car wash and ready for collection.
Cheers,
Another BMW F10 swing back to Revol Carz Garage for under coat cover replacement.
For more information on Revol Carz Garage repair services, please feel free to contact us at 65551171 or Sms / WhatsApp Gavin at 9740 6855 for a no obligation discussion
Cheers,
