Re: Car Repair & Servicing Photo Gallery
Car servicing at Revol Carz Garage is never simply a quick touch-and-go, oil change and filters affair.
Our standard policy is serving every car arriving at our garage with a comprehensive servicing undergoes meticulous and stringent inspection by our certified professional mechanics.
All oil leakage repair works and rectification repairs works comes with a 6 months warranty to provide car owner with peace of mind.
To find out more information of Revol Carz Garage car servicing packages, please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
You may also text us by SMS / WhatsApp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Another BMW F10 swing by to Revol Carz Garage for car servicing services
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior.
Thank you for reading!
Cheers,
Revol Carz Garage Management Team
#02-18 AMK Autopoint S568047
Garage Appointment Hotline: 6555 1171
Revol Carz Makeover;1125656 said:
Hi Everyone,
Another BMW F10 swing by to Revol Carz Garage with complains of oil burning smell while the engine is running. Our experience senior mechs immediately spotted the source of the oil burning smell- valve cover engine oil leakage.
Over time, valve cover gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, it will drop out from the valve cover.
The engine oil that is dripping out from the valve covers creating the engine oil burning smell.
Worn Valve cover gasket replaced and all is well now.
To find out more on Revol Carz Garage servicing services or having oil leakage issue, please feel free to contact Gavin at Hp: 9740 6855
Cheers,
This is my car that I asked Randy to help check on the burning oil smell. I just serviced it and had a carbon clean job done at another site sponsor ws but they failed to notice this issue. Came back from a bz trip and when I started the car, doesn't smell right. And since I have a grooming session with Revol, decided to let them try it out since it's convenient. They found the problem, fixed it and I cannot be any happier. At last, I found someone who is not pushy and is able to do a proper job. Yesterday, I send it for servicing at Revol. I have been there all the while and monitor all the work done. I have to say that the mechanic is organize, detail and friendly. They entertain any questions without getting annoy. Together with me was my BIL's F30 with brake issue. Not a big job but they did it with full commitment and to top it off, it was a last min appt. I have to say that Revol garage is really one of a kind workshop that I have not seen for so many years. I will continue to support this workshop till I'm able to find a better one or they screw up like those previous ones that i have patronized. For a new player, they have clearly outdone themselves.
Keep it up Revol.
Having problem to unlock the door? It could be a door lock actuator that needed a replacement!
A door lock actuator is the component in electronic door locks that is responsible for locking and unlocking the vehicle’s doors with a press of a button. The lock is triggers by a small motor when then triggers a sense of gears to lock and unlock the doors.
Having issue unlocking your door?
BMW F10 dropping by for door lock replacement
Inner Door panel removal in process
Door lock actuator replacement in process
Cheers,
Keep it up Revol.
Hi The guardian,
Thank you so much for your continuous support in using Revol Services!:thumbsup:
Appreciate it very much!
Great to know you are happy with our car repair services too.
Will keep up the good works ya.
Catch up with you on your next visit!
Cheers,
Best Regards,
Gavin Tan
Revol Carz Garage Appointment Hotline: 6555 1171
What happens when all exterior oil leakage has been fixed up and yet you are topping up engine oil at every 1k?
An owner decided to seek a 2nd option at Revol Carz garage and the outcome…. We have another happy customer.
At Revol Carz garage, we will perform various tests to determine before recommending the best option to solve your problem.
In this case, there is no exterior oil hence we advise and perform a valve seal replacement which solves his engine oil consummation problem at a small fraction rate as compare to a full engine overhaul!
Facing engine oil high consumption issue?
Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Another E60 arriving Revol Carz Garage for Valve seals replacement.
Valve seals replacement in process
BMW special tools are required to perform valve seals replacement
The removal of the worn out valve seals
Best Regards,
Hi All
I would like to share my recent experience with Gavin.
For many years, I have been sending my car for servicing and repairs at another workshop (JFC), and spent thousands and thousands of dollars each time to their workshop. Problems like engine oil disappearing and air-con water leaking into the car were never solved. They will always say "BMW is always like this..." or they try to get me to repair other parts so they can earn more money. Even with my air-con leak, they didn't even do a proper repair and problem came back within 2 days. Worst, I found out from Gavin that my rear tyres were totally bald (proof of photos), and this was never detected by JFC. Gavin mentioned that my car tyres could blow out if hit a hard object. This comprises my family and my safety. I was totally shocked when I did some servicing not long ago. Totally disgusted with JFC.
When I read the forum and heard many testimonials, I decided to give Revol a try. Man I must say, I'm a very happy driver now. So far, I don't have engine oil disappearing for almost 2 weeks and still at FULL level. My air-con is fixed which they did it for free. A new radiator which was leaking coolant (again not detected by JFC). And of course, replace a new set of rear tyres.
Kudos to Gavin and Randy for their professional services, and their transparency. I'm now not only sending my car for grooming, but also servicing/repairs.
Another BMW 320I swing by at Revol Carz Garage for Car servicing, brake rotor and disc replacement.
Brake rotor and brakes pad are always replaced at a certain millage.
Proper maintenance with the correct replacement of your brake pads is deeming one of the most important safety measure.
With good proper brake maintenance, it can reduce the risk of accident with shorter and more effective braking distance hence reducing the risk of you and others.
Not sure if your brake pad or rotor is due for replacement?
Another BMW 320I swing by at Revol Carz Garage for brake rotor and pads replacement.
Car servicing in process
Brake rotor replacement in process
New brake rotor fitted in professionally
Best Regards,
luckybull;1131587 said:
Hi All
Hi luckybull,
Thank you so much for your compliments posting! :thumbsup:
We appreciate your continuous support in using Revol Carz Garage services.
We are glad to know your engine oil disappearing and air con issue have been resolved fully.
Do feel free to contact us if you do need any of our assist ya.
Looking forward to serve you again on your next visit!
Cheers,
Best Regards,
Gavin Tan
Another BMW F10 drop by to Revol Carz Garage for car servicing and Auto transmission fluid replacement.
A successful rule of maintaining a good transmission and extending the service life is that car should get a transmission fluid service replacement as per recommended millage. An inspection is recommend to be carry immediately once you notice any fluid underneath the car.
Not sure if your car is due for auto transmission fluid replacement?
You may also SMS / WhatsApp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Auto transmission oil replacement in process
Best Regards,
BMW 130I back at Revol Carz Garage for Car servicing, brake rotor and pads replacement.
Proper maintenance with the correct replacement of your brake pads is deem on of the most important safety measure.
Brake rotor are removed carefully
New Brake rotor awaiting replacement
New Brake rotor fitted professionally
Best Regards,
Happy Lunar New Year to Everyone!
We wish you and your family a Prosperous Happy Lunar New Year filled with Good Health and Success...
Kindly be informed that our workshop will be closed
from the 7th February’16 to 14th February’16
in celebration of the Lunar New Year.
Business will resume on the 15th Feb’16 at
Ang Mo Kio and 18th Feb’16 for Toh Guan
We thank you for your continuous support!
Best Regards,
Another BMW E60 swing by to Revol Carz Garage for car servicing servicing
Another BMW E60 swing by to Revol Carz Garage for car servicing services
A leaking steering pump oil leakage
Issue resolved
Best Regards,
Another F30 swing by at Revol Carz Garage for battery replacement.
At Revol Carz Garage, we make sure every battery changed will be performed with profession battery registration coding on the IBS to ensure it is properly installed
For more information on battery replacement, Please feel free to drop by at our Revol Carz Garage or contact us at 6555 1171.
New Battery awaiting replacement
Best Regards,
Best Regards,
Over time, Oil slump gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, a regular top up of engine oil is required
Not sure if your oil leakage is due to a worn out oil slump gasket?
Another BMW 320i coming for oil slump gasket replacement.
During oil slump gasket removal, our professional technician will ensure a thoroughly clean gasket before replacing back
A thoroughly clean gasket fitted back professionally
Best Regards,
Another F20 swing by at Revol Carz Garage for battery replacement
For more information on battery replacement, please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Another F20 swing by at Revol Carz Garage for battery replacement.
Used Battery
New battery
Best Regards,
Another BMW 320i dropping by at Revol Carz Garage for car servicing services
Best Regards,
6555 1171
Over time, valve cover gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, engine oil will drop out from the valve cover.
Another BMW E60 dropping by Revol Carz Garage for car servicing and valve cover gasket replacement
Revealing the inner engine and Valve cover gasket replacement in process
Best Regards,
Having the needs to top up regularly of your coolant means a leakage have started...
Having a check by our professional will ensure to prevent bigger leakage which may lead to engine overheating.
We have another BMW F10 swinging by Revol Carz Garage for inspection check and our experience technician immediately spotted the leaking hoses.
Not sure if frequent topping up of coolant is due to a leaking hoses?
Another BMW dropping by Revol Carz Garage for car servicing and coolant hoses replacement!
Replacement of the worn out hoses
New hoses replaced to ensure no more leakage!
Best Regards,
Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171 to find out more on our car servicing packages.
Best Regards,
