You would be quite devastated if your engine oil is contaminated with coolant.
We are glad to have prevented a BMW F10 from such adversity.
BMW model F10 520i are commonly subjected to this phenomenon. Although the engine oil and coolant each run its path but once the ageing plastic oil filter’s housing gets deteriorated due to heat exposure and once it cracked, the mixture of the coolant and engine oil will occur.
If that really happen, it will be quite messy to resolve as it will need repeated coolant flushing in order to get rid of all the engine oil in the engine cooling system.
We do strongly recommend that if you are having a plastic oil filter housing in your car make, get it replaced to the aluminium type as a preventive measurement!
Please feel free to drop by our Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
You may also text us by SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
BMW F10 520i arriving revol Carz garage for aluminium oil filter housing replacement
The plastic oil filter housing
The new aluminium oil filter housing awaiting replacement
New oil filter housing installed and highly recommend for preventive measure!
All cars serviced or repaired at Revol Carz Garage receive a complimentary car wash and full interior vacuuming.
Best Regards,
Revol Carz Garage Management Team
#02-18 AMK Autopoint S568047
Revol Carz Garage Appointment Hotline: 6555 1171
At Revol Carz Garage, we make sure every battery changed will be performed with profession battery registration coding on the IBS to ensure it is properly installed
For more information on battery replacement, please feel free to drop by our Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Another BMW F10 arriving Revol Carz Garage for car battery replacement
Used battery
Original BMW Battery replacement professionally with registration coding done
Best Regards,
The Differential is a special gearbox located between the drive wheels of your car. It allows the outer drive wheel to rotate faster than the inner drive wheel during a turn. This is necessary when the vehicle turns, making the wheel that is traveling around the outside of the turning curve roll farther and faster than the other.
Replacing the fluid will help to prevent premature wear on the gears in the differential and hence reduce the wear on drive wheel tires.
Not sure if you need a differential oil replacement?
Another F10 arriving at Revol Carz Garage for Differential oil replacement
Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
27735707850_a7a74fbecf_z.jpg" width
Car hoisted up
Best Regards,
Wishing All a Joyous Selamat Hari Raya!
Best Regards,
What happens when all exterior oil leakage have been fixed up and yet you are topping up engine oil at every few k millage? Its time to look at the valve seal then..
At Revol Carz garage, we will perform various tests to determine before recommending the best option to solve your problem. In this case, there is no exterior oil hence we advise and perform a valve seal replacement which solve his engine oil consummation problem at a small fraction rate as compare to a full engine overhaul!
Facing engine oil high consumption issue?
Another BMW E90 dropping by at Revol Carz garage for valve seals replacement
Valve seals replacement is progress
New valve seals awaiting replacement
Valve seals replacement done
Best Regards,
Shock absorbers is a mechanical or hydraulic device designed to absorb and damp shock impulses. They are mounted from the suspension to the frame of the car and when driving over uneven surface or humps, the pistons inside the shock move up and down against the liquid or gas.
Over time due to usage, a worn shock absorbers will results in an unstable ride with annoying knocking sound for severe worn out shock absorbers.
Not sure if your shock absorbers are due for replacement?
Do feel free to contact us at Phone: 6555 1171 or SMS and Whatsapp us at Hp: 9740 6855 for a no obligation discussion!
Another BMW F32 arriving Revol Carz Garage for shock absorber replacement
Car hoisted up
New shock absorber awaiting replacement
Best Regards,
For more information on battery replacement, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Another BMW E93 arriving Revol Carz Garage for car battery replacement
Used battery
New battery professionally replaced with registration coding done
Best Regards,
Car servicing at Revol Carz Garage is never simply a quick touch-and-go, oil change and filters affair.
Our standard policy is serving every car arriving at our garage with a comprehensive servicing undergoes meticulous and stringent inspection by our certified professional mechanics.
All oil leakage repair works and rectification repairs works comes with a 6 months warranty to provide car owner with peace of mind.
Another BMW 320i dropping by at Revol Carz Garage for Engine oil change.
To find out more information of Revol Carz Garage car servicing packages, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Another BMW E90 dropping by at Revol Carz garage for Car servicing service.
Car hoist up for stringent inspection
Best Regards,
A successful rule of maintaining a good transmission and extending the service life is that car should get a transmission fluid service replacement as per recommended millage. An inspection is recommend to be carry immediately once you notice any fluid underneath the car.
Not sure if your car is due for auto transmission fluid replacement?
Please feel free to drop by our Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 65551171.
Another E90 arriving Revol Carz garage for auto transmission fluid replacement
Car hoisted up
Auto transmission fluid replacement in progress
Auto transmission fluid replacement completed
Best Regards,
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior.
Best Regards,
Another E90 dropping by at Revol Carz Garage for valve seals replacement
Valve seals replacement in progress
Best Regards,
Having the needs to top up regularly of your coolant means a leakage have started..
Having a check by professional will ensure to prevent bigger leakage which may lead to engine over heating.
We have another BMW F10 swinging by Revol Carz Garage for inspection check and our experience technician immediately spotted the leaking radiator.
Not sure if your frequent topping up of coolant is due to a radiator leakage?
Another BMW F10 swinging by Revol Carz Garage for radiator replacement
The culprit of frequent coolant topping up
New Radiator awaiting replacement.
Best Regards,
The National Day of Singapore is celebrated every year on 9th August, in commemoration of Singapore’s independence from Malaysia in 1965.
Cheers to the 51st Years of Independence!
Best Regards,
A thermostat is a component of the cooling system that regulates the temperature of the coolant fluid in the engine. The thermostat sense the temperature with its build in temperature sensor.
It will either open of closed according to the temperature which it will then perform the required action.
A faulty thermostat will not be able to perform its required action which will in most cases lead to an engine over heating!
Another BMW 335i drop by to Revol Carz Garage for thermostat replacement.
Not sure if your thermostat is still in good working condition?
New thermostat awaiting replacement
Best Regards,
Over time, valve cover gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, engine oil will drop out from the valve cover.
Not sure if your oil leakage is due to a worn out oil cover gasket?
Another BMW E60 dropping by Revol Carz Garage for car servicing and valve cover gasket replacement
For more information on valve cover gasket replacement, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Valve cover gasket replacement in progress
Valve cover gasket replacement done
At Revol Carz Garage, we ensure the cover that have been stained will be professional clean before fitting back.
What the engine cover should really look like.
Best Regards,
What happens when all exterior oil leakage have been fixed up and yet you are topping up engine oil at every few k mileage? Its time to look at the valve seal then..
Facing engine oil high consumption issue? Do feel free to contact us at 6555 1171 or Sms/WhatsApp Gavin at Hp: 9740 6855 with a no obligation discussion to resolve your engine top up problem.
Another E90 dropping by Revol Carz Garage for valve seals replacement.
Valve seal replacement in progress.
Special tools are required for the valve seals replacement .
The new valve seals awaiting replacement.
Best Regards,
Another BMW E90 arriving Revol Carz Garage for car servicing services.
Car hoist up for preventive safety check
Best Regards,
The water pump is the heart of the cooling system. The pump circulates coolant between the engine and radiator to keep the engine from overheating.
Inside the pumpis a metal or plastic impeller with blades that push the water through the pump. If the water pump is not working, the coolant will not circulate through the cooling system causing the engine to overheat and get severe damages.
Not sure if your engine overheating is due to a faulty water pump?
Another E60 dropping by at Revol Carz Garage for water pump replacement.
Car hoisted up.
New water pump awaiting replacement
Best Regards,
Having the needs to top up regularly of your coolant means a leakage have started somehow!
Another BMW F10 swinging by Revol Carz Garage for inspection check and our experience technician immediately spotted the leaking radiator
Car hoisted up for inspection safety check
The new radiator awaiting replacement
Best Regards,
Wishing you and your family a Selamat Hari Raya Haji!
Best Regards,
fun886cc
