Car servicing at Revol Carz Garage is never simply a quick touch-and-go, oil change and filters affair.
Our standard policy is serving every car arriving at our garage with a comprehensive servicing undergoes meticulous and stringent inspection by our certified professional mechanics.
All oil leakage repair works and rectification repairs works comes with a 6 months warranty to provide car owner with peace of mind.
To find out more information of Revol Carz Garage car servicing packages, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
You may also text us by SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Another BMW E60 arrriving at Revol Carz Garage for car servicing services
Car hoist up for safety checks
And we are thankful to be able to inform the owner of the tyre condition.
All cars serviced and repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior.
Best Regards,
Revol Carz Garage Management Team
#02-18 AMK Autopoint S568047
Revol Carz Garage Appointment Hotline: 6555 1171
Anti-skid braking system (ABS) is an automobile safety system that allows the wheels on a motor vehicle to maintain tractive contact with the road surface according to driver inputs while braking, preventing the wheels from locking up (ceasing rotation) and avoiding uncontrolled skidding.
ABS generally offers improved vehicle control and decreases stopping distances on dry and slippery surfaces; however, on loose gravel or snow-covered surfaces, ABS can significantly increasebraking distance, although still improving vehicle control
Not sure if your car abs pump is having issue?
Another BMW e90 dropping by at Revol Carz Garage for ABS pump replacement
The new abs pump awaiting replacement.
Best Regards,
Another BMW F10 arriving Revol Carz Garage for engine mounting replacement.
Engine Mounting is connected from a car engine to the car frame. They are made of a combination of rubber and metal.
The 2 main function of the engine mounting is
1.Secures the engine to the frame of the car to minimise the engine movement.
2.To absorbs the vibration from road shocks so the drive will not feel the movement.
Same applies to the transmission mounting which have the above purpose.
If you are hearing sound from your engine compartment with slight vibration, it could be sign that your engine mounting is due for a replacement
Not sure if your engine mounting is due for replacement?
Car hoist Up
Engine mounting awaiting replacement
Best Regards,
What happens when all exterior oil leakage have been fixed up and yet you are topping up engine oil at every few k mileage? Its time to look at the valve seal then.
At Revol Carz garage, we will perform various tests to determine before recommending the best option to solve your problem. In this case, there is no exterior oil hence we advise and perform a valve seal replacement which solve his engine oil consumption problem at a small fraction rate as compare to a full engine overhaul!
Facing engine oil high consumption issue? Do feel free to contact us at 6555 1171 or Sms/WhatsApp Gavin at Hp: 9740 6855 with a no obligation discussion to solve your problem.
Another BMW E60 arriving Revol Carz Garage for valve seals replacement
Car hoist up
Is is always part of job to ensure your safety is our most important priority!
Special tools is required for Valve seals replacement.
We are glad to be able to resolve the high engine oil consumption issue for this owner.
Best Regards,
Over time, valve cover gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, engine oil will drop out from the valve cover.
Not sure if your oil leakage is due to a worn out oil cover gasket?
Another BMW F10 dropping by Revol Carz Garage for car servicing and valve cover gasket replacement
For more information on valve cover gasket replacement, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Another BMW F10 dropping by Revol Carz Garage for car servicing and valve cover gasket replacement.
Valve cover gasket replacement in progress.
After the valve cover is removed exposed the inner engine.
Valve cover gasket replacement done professionally
Best Regards,
Brake rotor and brakes pad are always replaced at a certain millage.
Proper maintenance with the correct replacement of your brake pads is deem on of the most important safety measure.
With good proper brake maintenance, It can reduce the risk of accident with shorter and more effective braking distance hence reducing the risk of you and others.
Not sure if your brake pad or rotor is due for replacement?
Another BMW 335i arriving at Revol Carz Garage for brake rotor replacement.
Car hoist up for brake rotor replacement.
New brake rotor awaiting replacement .
Best Regards,
Another BMW F30 arriving Revol Carz Garage for car servicing services.
Car hoisted up for safety check.
Best Regards,
Another BMW F10 arriving at Revol Carz Garage for car servicing & brake rotor replacement.
New brake rotor fitted professionally .
Best Regards,
Over time, Oil slump gasket due to heat will start to harden and shrink. Engine oil will start leaking from the worn out gaskets and in more serve cases, a regular top up of engine oil is required
Not sure if your oil leakage is due to a worn out oil slump gasket?
Another BMW 320i coming for oil slump gasket replacement
For more information on oil slump gasket replacement, Please feel free to drop by our Revol Carz Garage or contact us at 6555 1171.
Oil slump gasket replacement in progress
Oil slump gasket replacement done
Best Regards,
Another BMW F30 arriving at Revol Carz Garage for brake rotor replacement.
Please feel free to drop by our Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Used brake rotor awaiting replacement
New BMW rotor fitted professionally .
Best Regards,
Wishing you and your family Happy Deepavali!
Best Regards,
Another BMW E90 arriving Revol Carz Garage for car servicing services
To find out more information of Revol Carz Garage car servicing packages, please feel free to drop by our Revol Carz Garage at 10, Ang Mo Kio Industrial park 2a # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Best Regards,
Brake rotor and brakes pads should be replaced at regular intervals according to the car-maker’s manuals.
Proper maintenance and correct replacement of your brake pads is an important safety consideration. Efficient braking system enables you to stop your car in good time, reducing the risk of a road accident.
Not sure if your brake pads or rotors are due for replacement? Let our professional mechanics check for you.
Please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial Park 2A # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Another BMW 523I A arriving at Revol Carz Garage for brake rotor replacement.
Best Regards,
Car air conditioner blower motor generates forced cool air through the ventilations. The fan speed and temperature can be controlled through switches and dials on the car dashboard.
Faulty motors can cause poor air circulation, noisy operation or no cold air blows through the ventilations.
Diagnosing these complaints often begin with checking the electrical systems connecting the blower motor.
In extreme cases, we discovered rodents trapped in the fan chamber.
When all the diagnoses confirm the motor has indeed broken down, we recommend replacement of the blower motor.
Here is a BMW 730LI patronizing Revol Carz Garage for the air condition blower motor replacement.
Brand new blower motor awaiting replacement.
Best Regards,
The job of a thermostat is to maintain a minimum operating engine temperature in your car.
When you start the car cold, the coolant flows through the radiator to maintain the rated temperature within the engine by the thermostat.
If your thermostat is stuck partially or completely open, it will cause the engine to take longer time to warm up. Conversely, partially opened thermostat may not allow enough coolant to flow at high speed to keep the engine from overheating.
Your thermostat is faulty if the engine warms up too slowly, never reaches normal temperature or overheats quickly.
As a preventive maintenance procedure, it is recommended to have your thermostat replaced when the next cooling system is being serviced. Most car makers recommend a cooling system flush and refilled every two years.
It might be a good idea to have it replaced the next time your cooling system is being serviced as a preventive maintenance procedure. Most manufacturers recommend a cooling system reverse Flush and refill every two years.
Do you find your car’s engine temperature erratic? If you are unsure, don’t hesitate to drop by Revol Carz Garage for a peace of mind. Our experienced mechanics will inspect and advise on your coolant system.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Another BMW 320i drop by to Revol Carz Garage for thermostat replacement
The car is lifted for inspection and repair works.
New thermostat awaiting replacement
Best Regards,
Regular servicing is the key preventive maintenance measure in keeping your ride happy, safe and saving you money in the future.
Good mechanics will explain to you the repair phases and conduct a systematic multiple points check including primarily changing the engine oil, oil filter and air filters,
We keep computerized records of cars serviced
Generally there are two types of car servicing. The minor service is required every ten thousand kilometers. The major servicing is generally every thirty to forty-five thousand kilometers.
The best guide for the car owners is to refer to the manufacturer’s manual.
Don’t ignore regular preventive maintenance servicing. Arrest a small fault before it becomes a major problem that burns a huge hole in your pocket.
At Revol Carz Garage, our certified mechanics resent unscrupulous touch-and-go attitude. Some workshop resort to hurried and easy servicing job with oil and filter change and go.
We double-check and maintain every part of your car in our servicing protocol. We communicate with the car-owner for any worn-out or broken parts before replacing.
Our integrity and uncompromising workmanship keep our loyal customers coming back.
Please drop by our Revol Carz Garage or on your next oil change. Our competent mechanics about ensuring your car is safely on the road again.
Revol Carz Garage is located at Blk 10, Ang Mo Kio Industrial Park 2A, # 02-18 Ang Mo Kio AutoPoint.
You can reach us at 6555 1171 or SMS/WhatsApp to our Workshop Manager, Gavin at 9740 6855 for a friendly and absolutely no-obligation consultation
Another BMW 320i visits Revol Carz Garage for regular servicing.
The BMW 320i is jacked up for under-carriage inspection and servicing protocol.
All cars serviced and oil-changed at Revol Carz Garage receives foam wash and vacuuming and cleaning of the interior
Best Regards,
To get an engine to start, it must be turned (or crank) at some speed so that it sucks air and fuel into the cylinders and compress them. A powerful electric starter motor does the turning job
Starter failures are not all caused by a faulty starter motor although some common failures are contributed by worn out carbon brushes, poor contact points or the armature bearing and weak battery.
Starting system problems are common and not all problems are caused by a faulty starter motor. To find the cause of the problem in the starting system, your mechanics may need to measure the starter electrical control circuit.
The starter motor itself may fail due to wearing of the carbon brushes and other internal parts. If the starter is faulty, it should be replaced.
Having difficulty starting your car? You can get help immediately when you call Revol Carz Garage at 6555 11171.
We are located at. Blk 10, Ang Mo Kio Industrial Park 2A # 02-18 Ang Mo Kio AutoPoint
You may also SMS / Whatsapp to our Workshop Manager, Gavin at 9740 6855 for friendly and absolute no obligation consultation.
Another BMW 750LI drop by to Revol Carz Garage for thermostat replacement.
The BMW is lifted in preparation for safety checks and part replacement work.
A new starter motor awaiting replacement.
Best Regards,
In our hot and humid tropical climate, the car air-conditioning is critical in keeping us cool and comfortable in our ride. The cooled gas chills the air in car’s cabin.
The car air-conditioner gets a lot of usage but we may not think much about the compressor works overtime to bring us comfort. The compressor does exactly what the name implies. It compresses refrigerant and sends it to your car’s air condenser.
Like other car parts, the compressor expects the wear and tear over the years until no cool air coming from the system.
If your car’s air-conditioning is not blowing cool air, don’t hesitate to visit Revol Carz Garage for diagnosis. We have the right analyzer and scan tools. Our certified mechanics will give you the right advice for replacement parts.
We are located at Blk 10, Ang Mo Kio Industrial Park 2A # 02-18 Ang Mo Kio AutoPointOr contact us at 6555 1171.
A BMW 520I arrives at Revol Carz Garage for air conditioner compressor replacement.
The vehicle is lifted for inspection and compressor replacement works.
New air conditioner compressor awaiting replacement
Best Regards,
To find out more information of Revol Carz Garage car servicing packages, Please feel free to drop by our Revol Carz Garage at Blk 10, Ang Mo Kio Industrial Park 2A # 02-18 Ang Mo Kio Autopoint or contact us at 6555 1171.
Another BMW 320IXL has arrived at Revol Carz Garage for car servicing services.
Car elevated for systematic safety inspection.
Best Regards,
If your car has been running poorly, misfiring and stops erratically during the drive, it is possible that you have bad ignition coils and/ or spark plugs.
The most common symptom of ignition coil failures is caused by worn out spark plugs. A faulty ignition coil also causes the engine stall abruptly after the car runs for a while.
If your car has been annoying you with these symptoms, let us inspect the ignition system for you. There may be other causes too.
You may also SMS / Whatsapp to Gavin at 9740 6855 for friendly and absolute no obligation consultation. We’ll make your drive a happy one again.
We have another BMW 525I XL arriving at Revol Carz Garage for car servicing and resolving the ignition coils problem.
Diagnosing in progress.
New ignition coils awaiting replacement.
All cars serviced or repaired at Revol Carz Garage receive complimentary car wash and vacuuming of the interior. This is one of our ways to show great appreciation.
Best Regards,
fun886cc
