Coil over recommendation. Ride too soft!
Thinkbig
Hi guys, opening a new topic on this.
I recently changed my springs to HnR ones and got the low ride look that I wanted. However, I find that the ride is too soft. I'd like to have back my ride to have its original 'hardness' but will sit the car as low as this.
What brand and model of coil overs would you recommend? And which shop?
Thank you so much!!
Re: Coil over recommendation. Ride too soft!
KW V3 bestest ....... for the price its going
KW V3........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
KW V3 is definitely the best....but otherwise if you want something basic and idiot proof...V1 hahaha
i know some people use BC..but so far no reviews on that yet. price difference about 1k
Yeah I have been reading too. V3 is good. Do you guys know how much is the damage, with installation? Just an estimate would do. Thank you.
Maybe around 2.5k including shipping.
Your rims not flush with fenders .....
3k region............if not ST V1 ( 2K region )
V1 is around 2-2.5K including labour depending on which workshop you go to. V3 is nearing 3K region. BC is 1-1.5K
but these are based on prices 1 year ago...
KW V1 i think about 2k only
V2 about 2.5k if got stock
What about Biestein & Eibach/H&R combo, dropped and no need to bother about adjusting possibly 1k+?
Probably need 10/15mm spacers to push out or change to staggered tires.
Any bad after effects of using spacers though?
Its about $2k for Bilstein shock with H&R springs..
Since on H&R liao, go for aftermarket damper will do if adjusting of height & damping is not priority..
Just curious, why would aftermarket spring be softer than stock spring.. :thinking:
For street use, go for KW2 or PSS9 will do.
10-15 mm is fine. Anything more and stress will be loaded on suspension joints such as tie rods and links.
was on bcbr before...very good ride...no knock knock noise and always on ready drift mode...
Just wondering if anybody has the m-sport suspension/H&R springs combo b4 ? If so whats the height drop like and how does it look on a say 18 inch rim. ?
what is your definition of hard ? like go-kart ?
Thank you so much!!
Go with KW V3... Just got mine fixed today. Brilliant, no regrets.
How does V2 differ from V3..??
Soory but I'm not very familiar w coilovers..have been on stock M sport since day 1..
sunwinselect
