richlee7
Hi guys, just to share a relatively simple DIY to change from stock (leather) parking brake lever to any others, which in my case, i changed to the aluminium-leather one.
Time taken : 15 minutes
BMW Part No. : 34 40 0 404 523
Tools needed:
1. Cable tie: 200mm x 5mm, black will be better.
2. Plastic cutter: available fm most DIY shops
3. Sharp pen-knife or scissors (if you do not have plastic cutter, but use with more care)
Removing:
Open the arm-rest for easy access to the parking brake leather boot.
Disengage leather boot from centre console. This is a whole module with the leather almost 'fused' to the mount.
Cut cable tie to remove leather boot.
Remove brake lever by pulling it with slight strength. It's not necessary to over-exert strength.
Installation:
Install new (aluminium-leather) brake lever, and push in till it engages with a slight 'click'.
Tools needed:
Removing:
Installation:
