Drivetrain /Driving Stabilization /Flat Tyre Monitor (RPA) Failure
f30_issue
New Member
Hi, does anyone seen these problems before as described below.
I have verified that all 4 wheel speed sensor are giving consistent identical readout within a monitoring period of 5mins. Wondering what could be at fault here as there are various codes displayed.
Vehicle: 2014 BMW F30 316 N13
Fault Displayed On Dash
  • Drivetrain
  • Driving Stabilization
  • Flat Tyre Monitor (RPA) Failure
Fault Displayed with OBD- ERROR Memory
Digital Motor Electronics
107A81: THROTTLE VALVE, CLOSING SPRING TEST: MALFUNCTION
100101: THROTTLE VALVE, FUNCTION: PERMANENTLY CLAMPED
107A70: THROTTLE VALVE, ACTIVATION: SHORT CIRCUIT
107A50: THROTTLE VALVE: EMERGENCY RUNNING ACTIVE
100A04: THROTTLE DAMPER, THROTTLE POTENTIOMETER 1 AND 2: DOUBLE FAULT
1C0101: ENGINE OIL PRESSURE CONTROL, PLAUSIBILITY, STATIC: PRESSURE TOO HIGH
1C2001: ENGINE OIL PUMP: PRESSURE TOO HIGH
100201: THROTTLE VALVE, FUNCTION: STIFF, TOO SLOW
100001: THROTTLE VALVE, FUNCTION: TEMPORARILY STUCK
Integrated Chassis Management
D02D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
Dynamic Stability Control
4809AB: GLOBAL POWER SUPPLY - UNDERVOLTAGE EXTERNAL
D36D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
D35A57: SIGNAL ERROR (LONGITUDINAL ACCELERATION CENTER OF GRAVITY, ID:
ACLNX_MASSCNTR) – QUALIFIER
Fault Displayed with OBD- INFO Memory
Central Gateway Module
101008: UNRESOLVABLE AMBIGUOUS ROUTING - SG NOT IN THE SVT TARGET TABLE
100600: FLEXRAY PROTOCOL STARTUP TIME IS TOO HIGH
100104: HW WECKGRUND ZGW
100203: DM SOFTWARE ERROR INFO WARNING
100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED
231501: ERROR MEMORY ENTRY: TRANSMIT BUFFER FULL
480115: DRIVING DYNAMICS SWITCH - FORCED ACTIVATION DSC
482651: FLOATING ANGLE ESTIMATOR - INPUTS NOT VALID SBS
482656: FLOATING ANGLE ESTIMATOR - INTERNAL DEGRADATION DUE TO SBS
4827B3: INTERNAL CONTROL UNIT - UNDERVOLTAGE AT TERMINAL 30
Front Electronic Module
804029: NVM_QUEUE_EEPROM
Instrument Panel Control Unit
E12C2F: INTERFACE HU (ACKNOWLEDGMENT REQUEST COMBINATION, 0X172):
SIGNAL FAULTY
E12C30: INTERFACE HU (STATUS SERVICE CALL TELEX, 0X30F): SIGNAL FAULTY
Integrated Automatic Heating / Air Conditioning System
078004: NVM_E_INTEGRITY_FAILED
Hi there, encountered the same 3 issues you had two days ago.... going to workshop to verify.... hopefully nothing serious.... haiz....
Hi Shamuz, sorry to hear that about your car.
I have symptoms of car going in limp mode and seeing my gear cycle from 1-8 when in sports/manual mode. Does yours also show the same symptoms?
Yes.... but i stop my car... off the engine for a while. Start it back and everything was back to normal.... till now only the rpa appears at times.... what bout urs?
My symptoms still show after off/on overnight. Keep me posted on your situation/fix :)
Will do... please keep me update if u have fix the problems.... cause the workshop im goin will only open next week on the 3rd of feb.... Drive safe bro...
today mine also same with 3 problems shown on idrive
roughly took how long to fix it ?
thanks
Hi, I have the same fault codes as F30 issue.Engine is lethargic with hesitation in acceleration..
throttle module is the throttle body?
Hello,
I have the same errors:
  • Drivetrain
Anyone figured out what is the issue?
Thanks
Hello,
  • Drivetrain
Thanks
wheel speed sensor issue......
cheeeeeeeeeeeeeeeeeeeeeeeeeeers
Thanks for your reply, should I replace all 4 then? ISTA doesn't show an error for a specific wheel
at times not all 4 are faulty...workshop should be able to check..
cheeeeeeeeeeeeeeeeeeers
11sin88com
