Drivetrain /Driving Stabilization /Flat Tyre Monitor (RPA) Failure
f30_issue
New Member
Hi, does anyone seen these problems before as described below.
I have verified that all 4 wheel speed sensor are giving consistent identical readout within a monitoring period of 5mins. Wondering what could be at fault here as there are various codes displayed.
Vehicle: 2014 BMW F30 316 N13
Fault Displayed On Dash
  • Drivetrain
  • Driving Stabilization
  • Flat Tyre Monitor (RPA) Failure
Fault Displayed with OBD- ERROR Memory
Digital Motor Electronics
107A81: THROTTLE VALVE, CLOSING SPRING TEST: MALFUNCTION
100101: THROTTLE VALVE, FUNCTION: PERMANENTLY CLAMPED
107A70: THROTTLE VALVE, ACTIVATION: SHORT CIRCUIT
107A50: THROTTLE VALVE: EMERGENCY RUNNING ACTIVE
100A04: THROTTLE DAMPER, THROTTLE POTENTIOMETER 1 AND 2: DOUBLE FAULT
1C0101: ENGINE OIL PRESSURE CONTROL, PLAUSIBILITY, STATIC: PRESSURE TOO HIGH
1C2001: ENGINE OIL PUMP: PRESSURE TOO HIGH
100201: THROTTLE VALVE, FUNCTION: STIFF, TOO SLOW
100001: THROTTLE VALVE, FUNCTION: TEMPORARILY STUCK
Integrated Chassis Management
D02D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
Dynamic Stability Control
4809AB: GLOBAL POWER SUPPLY - UNDERVOLTAGE EXTERNAL
D36D58: SIGNAL ERROR (WHEEL TORQUE DRIVE 1, ID: WMOM_DRV_1) - QUALIFIER
D35A57: SIGNAL ERROR (LONGITUDINAL ACCELERATION CENTER OF GRAVITY, ID:
ACLNX_MASSCNTR) – QUALIFIER
Fault Displayed with OBD- INFO Memory
Central Gateway Module
101008: UNRESOLVABLE AMBIGUOUS ROUTING - SG NOT IN THE SVT TARGET TABLE
100600: FLEXRAY PROTOCOL STARTUP TIME IS TOO HIGH
100104: HW WECKGRUND ZGW
100203: DM SOFTWARE ERROR INFO WARNING
100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED
231501: ERROR MEMORY ENTRY: TRANSMIT BUFFER FULL
480115: DRIVING DYNAMICS SWITCH - FORCED ACTIVATION DSC
482651: FLOATING ANGLE ESTIMATOR - INPUTS NOT VALID SBS
482656: FLOATING ANGLE ESTIMATOR - INTERNAL DEGRADATION DUE TO SBS
4827B3: INTERNAL CONTROL UNIT - UNDERVOLTAGE AT TERMINAL 30
Front Electronic Module
804029: NVM_QUEUE_EEPROM
Instrument Panel Control Unit
E12C2F: INTERFACE HU (ACKNOWLEDGMENT REQUEST COMBINATION, 0X172):
SIGNAL FAULTY
E12C30: INTERFACE HU (STATUS SERVICE CALL TELEX, 0X30F): SIGNAL FAULTY
Integrated Automatic Heating / Air Conditioning System
078004: NVM_E_INTEGRITY_FAILED
Hi there, encountered the same 3 issues you had two days ago.... going to workshop to verify.... hopefully nothing serious.... haiz....
Hi Shamuz, sorry to hear that about your car.
I have symptoms of car going in limp mode and seeing my gear cycle from 1-8 when in sports/manual mode. Does yours also show the same symptoms?
Yes.... but i stop my car... off the engine for a while. Start it back and everything was back to normal.... till now only the rpa appears at times.... what bout urs?
My symptoms still show after off/on overnight. Keep me posted on your situation/fix :)
Will do... please keep me update if u have fix the problems.... cause the workshop im goin will only open next week on the 3rd of feb.... Drive safe bro...
today mine also same with 3 problems shown on idrive
roughly took how long to fix it ?
thanks
Hi, I have the same fault codes as F30 issue.Engine is lethargic with hesitation in acceleration..
throttle module is the throttle body?
Hello,
I have the same errors:
  • Drivetrain
Anyone figured out what is the issue?
Hello,
  • Drivetrain
wheel speed sensor issue......
cheeeeeeeeeeeeeeeeeeeeeeeeeeers
Thanks for your reply, should I replace all 4 then? ISTA doesn't show an error for a specific wheel
at times not all 4 are faulty...workshop should be able to check..
cheeeeeeeeeeeeeeeeeeers
Hey guys, got the same issue on my 2012 116i, drivetrain error, flat tyre monitor error and driving stabilisation. Got recovered by the aa and they diagnosed it as the throttle valve. Will cleaning it solve the issue as I really want to avoid paying £440 for a new throttle body. I've included a pic and a video it it'll help diagnose the problem. I know I need to change the break pads! Lol
Most likely speed sensors failure.
My drive F30 335i had the 4th sensor failure just last week. Changed and all 4 sensors had been replaced.
