Re: E60 questions
kahhao47;794101 said:
hi guys, sorry to hijack, but is there any difference between pb and velocity?
Hi Kahhao,
TUNE YOUR NON-TURBO BMW WITH THE
MORE HORSEPOWER! & MORE TORQUE!
Plus Adjustable Throttle Pedal Re-Mapping for Snappier Response
125i 128i 130i 323i 325i 328i 330i 523i 525i 528i 530i X3 X5 Z4 630i 730i
The BMS Power Box is a piggyback style performance chip for the BMW 2.5L & 3.0L N51/N52/N53 6 cylinder motors. It features easy installation and removal, gas pedal switching between 7 performance maps, throttle remapping for snappier response, and dyno gains of up to 10+ Horsepower and 10+ lb-ft Torque. Finally you can enjoy the car how it should have come from the factory.
• Up to 10+ More Horsepower & 10+ More lb-ft Torque
• Throttle Re-mapping for Better Response / Reaction
• Removes "dead area" delay in gas pedal
• 7 Different Maps / Settings
• Can be turned on and off from inside the car
• Gives even more Power with intake/exhaust or other mods
• Plug & Play, No cutting or splicing
• Made in U.S.A.
Installation takes around 20 minutes using basic hand tools and is completely reversible with no cutting of wires. Simply extract the factory wire and replace it with the corresponding BMS Power Box wire. Installation is very discrete allowing most customers to leave the unit installed for basic service is NOT TRACEABLE through the factory ECU/DME or the BMW dealerships equipment and does not hurt fuel economy during normal driving.
Dynos below show horsepower and torque increase at the wheels over stock.
BMS Power Box on a completely Stock automatic BMW 328i on 91 octane. BMS Power Box on a completely Stock automatic BMW 328i on 91 octane. NEW! BMS Power Box on a completely Stock automatic BMW 330i on 91 octane.
BMS Power Box Map Guide
Map 0 - Disables BMS Power Box (Stock)
Map 1 - 30% throttle remapping, performance tuning on
Map 2 - 60% throttle remapping, performance tuning on
Map 3 - 100% throttle remapping, performance tuning on
Map 4 - 30% throttle remapping, performance tuning off
Map 5 - 60% throttle remapping, performance tuning off
Map 6 - 100% throttle remapping, performance tuning off
Map 7 - throttle remapping disabled, performance tuning on
* Velocity is a Sprint Booster with 4 maps.....................( thanks for Hi-Jacking )
