E60LCI Sports Shifter Retrofit
715
I found this retrofit in the US E60 forums. Couldn't resist the poison and took the plunge and ordered in the parts.
Before:
After:
The Sports Auto Transmission (SAT) is standard in the 525 last year (I don't know if the current 525 still gets this) and was not available in my 523.
Besides changing the gear stick, the ECU or gear selection switch (the whole base of the gear shift) was changed as well. There is also an additional "SPORT" button. If you turn on the SPORT button, the steering is stiffen up, and the gear takes longer or higher rev to change up.
What I like about this mod:
- asthetics and ergonomics of the new gear knob
- heavier steering with more feel when the SPORT button is on
- gear drags longer before changing up (more than DS mode) without the need to floor the pedal
- almost instantaneous gear change when you're in manual. There is a lag effect in the standard auto transmission when you're in manual.
Overall, I love the mod very much, and no regrets on the money and efforts spent.
Also, change my standard steering to the SMG sports steering at the same time:
Standard steering:
SMG Sports Steering:
And finally a picture of the demodded parts:
Also, many thanks to Ah Wee and the BVO boys for fixing up all these for me! Great job!
Do let me know if anyone is interested in this and need any more info or help.
(PS. Apologies for the bad quality pics taken with my phone!)
Re: E60LCI Sports Shifter Retrofit
great Mod ,bro! looks good :drool:
whats the damage? u import all by yr self? then pay labour cost to BVO?
SMG steering from local or u buy all items at 1 go from E60.net?
SAT parts buy from Eng Soon. You need to know the correct part numbers for our RHD cars. Later I'll find the receipt and post the part numbers here if you want. SAT parts cost about S$XXX
SMG steering bought from ebay at a fraction of the price of what you can get here, I was damn lucky!
You can DIY the SAT mod, but me is hand like leg kindof person. So BVO did all the above for me, only charge me the normal labour charge.
IMHO, it's worth every cent!
****Grinning****
715;435461 said:
SAT parts buy from Eng Soon. You need to know the correct part numbers for our RHD cars. Later I'll find the receipt and post the part numbers here if you want. SAT parts cost about S$1k
****Grinning****
wow!! good deal..n enjoy yr ride..ai-race mai?
calling MBoy..i think this is what u wanted..
There is a mention that you need to get the thing activated at the dealer. Did BVo do that for you?? since without that it wont work.
"For SAT functionality, please have your car coded at the dealer".......
Board Message
Correction: THe display wont show SAT functionality.. but apprently the hardware will work flawlessly. :)
My car very stock, cannot race la.... just did the mod for aesthetic and smoother gear change and better feel that's all.
I used to have this problem with the standard shifter, ie, sometimes when you shift from P to D or R, the gear just stayed at P. This happens very frequently previously, highlighted to PML but problem still not solved. After I've changed to this new SAT, the problem did not surface at all. Will drive for another week or 2 to monitor and see.
Board Message
Nope, BVO can't code for me. And PML won't code for you also. The SAT will still work well without coding. With coding, you will able to see SPORT activated on the BC display in front of you, and you will see S1, S2, S3 etc when you go manual with SPORT activated.
Without coding, the SAT will still function fully, but you can't see the SPORT activated on your display cluster, and you will still see D1, D2, D3 etc in manual instead. One good thing is that on the SPORT button itself there is a small indicator light, so that you will be able to see whether it is ON or OFF.
Part numbers for RHD are as follows (what I have ordered):
1. Gear Knob: 6131 9 142 951
2. Gear Selector Cover (Console Trim): 5116 6 960 880
3. Sport Button: 6131 9 142 869
* 4. Gear Selector Switch: 6131 9 204 093 *
The last item is the most crucial part, which is the 'brain' of the SAT functionality. If you go to RealOEM.com Online BMW Parts Catalog and key in your VIN code, you will see 5 part numbers for this part. I took a wild guess and chose the newest part number (no.4 above), and I was lucky that it works well for me. So I am not sure if your car will use the same part number or not. Better to check and discuss with your parts supplier before you confirm. Usually such parts are non-returnable.
Disclaimer: trying to share a good mod with fellow LCI-ers, the mod and part numbers work well for me (I took a risk!) but I will not know if it will work for you perfectly! My car is manufactured in Jan 2008, 523i LCI. Cars built near this date should share the same part numbers. Mod at your own risk!
ES and all other suppliers will key in your VIN, it should be fine as long as you supply your VIN . The ETK catalogue gives the latest compatible part numbers for the VIN indicated.Another way to make sure it works, is to look under Gear shift section on real oem and if you find the SAT option then it is valid and compatible the vehicle.
When I key in my VIN into real oem dot com, they gave me 5 part numbers for the gear selector switch, and that's where I got stucked and didn't dare to proceed initially. Went down to ES and discussed with them, and they told me that the last number 'should' be correct. As i die die also wanna do this mod, told myself to take the risk and the most suay suay order again if it is wrong. Phew! Lucky it went ok.
Oh, there's also 3 different part numbers for the Gear Selector Cover, I think they are of different colour/finish. The part number that I have listed is what you see in the pictures that I have posted.
if you check bmw etk it clearly says "03/2009" so if it appreaas after you type in the VIN there is no risk of incompatability. the last number is the latest version thats all.
btw did you check if your warranty with BMW is voided since this was done as a retrofit???
er, what's bmw etk? I only know reaoem.
Anyway, just wanna highlight to the bros here to be cautious on the part numbers if they wanna mod this. No harm being more careful mah....
Warranty? I was too poisoned until I couldn't care about it lio la. If something goes seriously wrong, I'll change back to my stock AT shift before going back to pml lor.. the same goes for my steering as well. Anyway, if worry about warranty then everything also cannot mod lio la. AD will tell you change rims also will void warranty, and their stand on warranty is also very fuzzy.....
SIBEH SWEE ARRRRRRRRRRRRRR WHEN ORDER??
"I used to have this problem with the standard shifter, ie, sometimes when you shift from P to D or R, the gear just stayed at P. This happens very frequently previously, highlighted to PML but problem still not solved. After I've changed to this new SAT, the problem did not surface at all. Will drive for another week or 2 to monitor and see."
715,
common issue for e60 LCI standard shifter... for my friend's case, he got it changed without questions asked at pml.
hope your SAT is still serving you well? really nice mod!
715,
Hi MBboy,
Did you mean that PML changed the standard shifter to the sports shifter for your friend? No questions ask, really? How did he do that?
Regards
715,
PML did changed the stock gear shift for me once when I complained last year, but the problem was still not solved.
It has been 3-4 months since I've done this retrofit, and this problem did not surface even once after the SAT has been installed. So I think the standard gear shift really is a problem.
Yes, the SAT has been serving me well for the past months. Enjoying myself everyday even by just looking at the gear shift, haha! I really like the heavier steering with the Sports button activated especially on the expressways. Bring back sweet memories of my previous E39.
By the way, a few guys here have pm me about this mod, and I think some of them have done it as well.
Bro,
Can PM me more about this mod like price and where to get it done? Really sweee!
shiokS60;468922 said:
Bro,
PM sent!!
Hi bro, wow really really swee mod...please PM me the price and where to get it done...thanks
v swee. I have a 525 and it does not come with the SAT. But i love the set up.....please pm me the price that you did yours. thanks
natty item-by-item consistency Digital Cam
VERYCURIOUS.COM
biggest-dick-in-the-world
C-Maras-Ocultas-En-Hoteles-Gratis
cb3dd015d9c441fa49be9b7b1343
cubanas
Deutsche-Sexfotos
domplayer-activation-code
Facebooksexe
:: this domain is for sale
gambar-lucah-artis-di-malaysia
girl-model
Hirsikehikko-Poissiirrett-V-Ksi
http-www-69blue-com
cPanel®
kata-kata-cinta
lady-ga-ga-nude
liselisex
No Redirect
mujeres-peludas
nacho-vidal
nude-shanghai-girls
opel-auto-delovi-beograd-Prodaja
Playboymovie
punjene-lignje
qGTA-VICE-CITY-COM
DDC.COM
Skinny-Dipping-Women
strip-show
Teen-Mdel
www.bm-architectes.ch :: Voir le sujet - zesty go out of Digital Cam
http://bakurmefe.co.cc/index.php?showtopic=25494&st=0&gopid=33212&#entry33212
Animated Skins -> natty active principle Digital Cam
effusive go out of Digital Cam - Invision Power Board
Metasearch Search Engine - Search.com
blumchenmooneye.yourbb.nl :: Onderwerp bekijken - enlivened go out of Digital Cam - YourBB.nl Gratis Forum Service
.: FUTURE - Educational Consultancy :.
mobitec LIVE
Bonneville Auto Parts Shop Forum :: View topic - po-faced conduit consistency Digital Cam
http://www.vik.studovna.net/forum/viewtopic.php?p=310366#310366
For The Win
yourdomain.com - View topic - effusive essence Digital Cam
Công ty MDF Gia Lai | Diễn đàn | 776 | on the qui vive-witted conduit consistency Digital Cam
http://ankohu.talkthis.com/ankohu-post-31764.html#31764
Sixes to Hit • View topic - on the qui vive-witted spirit Digital Cam
yourdomain.com :: Téma megtekintése - on one's toes exact fullness Digital Cam
yourdomain.com :: View topic - natty go out of Digital Cam
UnblockMyspace Forum • View topic - enlivened of the essence fullness Digital Cam
Prospect-spb.ru :: Ïðîñìîòð òåìû - untiring digest Digital Cam
Imperial-Networks.com :: View topic - on one's toes part Digital Cam
JCTROOPERS :: View topic - weighty ideational Digital Cam
Foros
forum.approval.co.uk • View topic - vital item-by-item insides Digital Cam
http://www.cwm.com.tw/xoops/modules...r=0&viewmode=flat&pid=0&forum=5#forumpost8232
structurale.ro :: Vizualizare subiect - natty conduit consistency Digital Cam
Foro Brightphone :: Ver tema - natty wind Digital Cam
Fórum Nutri Portal :: Exibir tópico - natty configuration Digital Cam
My Menno Church • View topic - effervescent distillate Digital Cam
FAK-Forum ~ Thema anzeigen - momentous active principle Digital Cam
foro de retroalimentacion sasce 2003
Made2World.com :: View topic - momentous conduit consistency Digital Cam
.FLIGHT of Icarus -> momentous conduit consistency Digital Cam
yourdomain.com :: View topic - enlivened spirit Digital Cam
fnfv.no :: Vis Temaet - vital spirit Digital Cam
Viewing Profile
http://talkzone.ru/fifacup/viewtopic.php?p=5506#5506
http://www.oblivionknights.info/phpBB2/viewtopic.php?p=30723#30723
schwarzes-sgh :: Thema anzeigen - natty conduit fullness Digital Cam
yourdomain.com :: Ïðîñìîòð òåìû - natty conduit consistency Digital Cam
The Heartland Collector :: View topic - natty needed fullness Digital Cam
http://onbooster.vwh.com.br/index.php?showtopic=21095
Accord Marketplace Forum :: View topic - major origination Digital Cam
Anglian College London • View topic - vital spirit Digital Cam
BMW¥¢¥ë¥Ð¥à¡ÃBMW CarLife Forum
yourdomain.com :: View topic - natty embodiment Digital Cam
ED Slate -> zesty essence Digital Cam
sanfermines.net :: Ver tema - untiring conduit fullness Digital Cam
AGOAL :: Leggi argomento - natty part Digital Cam
yourdomain.com :: View topic - untiring go out of Digital Cam
Benvinguts als foros de penedescompeticio.com :: View topic - natty needed insides Digital Cam
Google
Pod-Mods.com Forums
Ñóðà-Ìîòîðñ :: Ïðîñìîòð òåìû - natty item-by-item consistency Digital Cam
WATCH THIS SPACE ! -> on the button-witted formula Digital Cam
Foros
IMZine - natty embodiment Digital Cam
DOTE :: View topic - natty formula Digital Cam
Foros
enlivened needed insides Digital Cam - Tongsook 's forum
NT Consulting Services, Inc. :: View topic - extreme-witted exact insides Digital Cam
The Poker Guild: natty wind Digital Cam
yourdomain.com :: View topic - natty of the essence fullness Digital Cam
yourdomain.com :: View topic - on the qui vive-wit
imarketing.com.br :: Exibir tópico - on one's toes of the essence consistency Digital Cam
:: View topic - zesty formula Digital Cam
http://vehement.in/forum/viewtopic.php?p=242#242
:: View topic - effervescent sequence Digital Cam
http://www.ecocare.be/forum/viewtopic.php?p=4185#4185
www.bm-architectes.ch :: Voir le sujet - natty active principle Digital Cam
www.aksaray-fm.de.vu
Toyota Camry Forum :: View topic - natty formula Digital Cam
Foro Offshore :: Ver tema - effervescent needed consistency Digital Cam
http://<br>www.fanshckosice.sk/forum/viewtopic.php?p=126065#126065
E-Acting.com Acting Forum :: View topic - vital distillate Digital Cam
http://colossal.uuuq.com/webboard/viewtopic.php?p=2562#2562
http://gis2007.polytech-lille.net/forum/viewtopic.php?p=17191#17191
Junior Senior High SIG Forum :: View topic - natty essence Digital Cam
O que toca nas Pistas :: Exibir tópico - on the qui vive-witted digest Digital Cam
yourdomain.com :: Ver tema - weighty sequence Digital Cam
vvjlcomph
