xtrava;868853 said:
Just had my car done up at one of the recommended workshop in JB Permas Jaya.
Problem:
I experienced knocking sound undercarriage, my regular workshop diagnosed it was due to some coupling stuff and propshaft mounting. Workshop in siggapore quoted $150 for labor alone.
Solution:
i purchased the parts from stockist and proceeded to the workshop in JB. The workshop specialise in Bimmers. Below are things i did to my ride and the breakdown of the costs:
1 Engine Flush RM25
2 Ultra Utimax 10W60 5litres RM238
3 Oil Filter RM38
4 Coolant RM55
5 Labor charge for Change engine oil and reset RM50
6 Labor charge for change valve cover Gasket & long shaft mounting RM220
Car was send in around 10am and collected at 230pm. The staff send me to Tebrau Jusco which is about 15 mins drive away to shop.
Engine bay was washed for oil stains after the valve cover change.
Total costs RM626.
Comments
Overall good experience with the workshop. Might consider bringing in my own engine oil and filter for next service.
Bro, can pm mi the shop details?
Thanks for the permas jaya workshop...was quoted Sgd $2.5k in sg workshop and 2 days down time...decided to be adventurous and headed north to ask 2nd opinion...permas jaya guy did it with Sgd $580 and in 3 hours. I took photos of what they changed before and afterand the boss took care to explain everything.
Post photos ?
Driving 2007 E90 mileage 110k km. When I went in, Francis first jacked up my car for inspection and explained all the parts that needs to be changed. He speaks good english too! Told me the price and if I am ok to proceed. After changing he kept all the removed parts as proof. If you want, you can stay and watch, but I decided to go to Jusco for grocery shopping and massage. Drive in at 1pm, collected at 4pm. Francis drove me to and fro Jusco so save taxi fare.:D
Here are the removed parts and items changed.
View attachment 40203View attachment 40204View attachment 40205View attachment 40206View attachment 40208
To be fair, I think SG workshops are better in terms of giving me peace of mind because its kinda risky to drive in due to unfamiliarity with road and the not so safe JB image. SG price is reasonably higher due to sky high rental and high labour charges. Furthermore, took me abit longer to find the place due to new roads contructed though its only 20 min drive from JB custom. Verdict, small problems below $500 I will do in SG. Big problems will go look for Francis in JB. Hope this helps!
U did top overhaul?
Not sure if it's top overhaul...guess mine was leaking quite bad with visible oil stains at top, front and bottom. But strangely it isnt eating engine oil, as in computer did not prompt to top up. Radiator hose also have visible signs of wear and tear. All the mechanics in sg workshops i brought to only popped the hood and started to shake their head and told me its big problem. So here comes francis in jb, who inspected with whole car jacked up, went underneath, shine with torchlight everywhere, removed some parts that blocked his view and diagnosed that dont need to change everything first to save cost. He showed me where the source of leakage and I just went along with his advice coz seriously unless u r a trained mechanic, u have to LL follow what they say. Maybe sg workshop just want to play save...maybe jb give lousy parts that's why cheaper? I will nv know. Just monitor and see.
Cool pics! Another satisfied BMW owner! =)
hey bros, any chance to share the contacts with me too?
many thanks in adv.
Did u bring your parts or Francis supplied? He usually would ask you to bring, then he charges you just labour.
10w60 oil is quite heavy, did you notice engine being more sluggish than before?
I got all my leaks fix car good as new, but now losing some oil through exhaust can see some smoke when revving hard.
It's either changing to thicker oil or major ops, ie engine overhaul soon :(
Problem:
Solution:
1 Engine Flush RM25
3 Oil Filter RM38
4 Coolant RM55
Total costs RM626.
Comments
Francis supplied. I did not know what parts to buy and I didn't want to come in another day.
Yeah that's the other alternative to bringing in your own parts. Good price and some savings, E90 got lots of maintenance
Can PM me this permas jaya workshop address? My E90 is drinking oil like every 1 mth and i saw quite some oil stains ard the engine. Previous owner serviced the car at PML, but can see that its very slipshod work. -.-
Hi bros, don't mind can PM me the details of the JB workshop that lkm bro is referring to? Thank you!
1 shop in sin ming quoted me SGD1200 to replace all gaskets. not sure if the saving worth the effort up north
lkm;705327 said:
I had a similar problem on my 2006 e90 - oil leak in engine bay. Mileage approx 100k. Sent to PML, and they quoted about $2k. Got a quote from one of the sponsor workshop here and was quoted $1k+ to replace "all related seals" to stop leak problem.
Not convinced, I brought car to my regular workshop in JB who specialises in BMW's. After diagnosis, mech replaced 2 o-rings at oil filter housing, and 4 more o-rings on the 2 VANOS solenoids. Viola! Oil leak no more and I'm poorer by less than RM270 - which includes my regular servicing. I brought my own oil, oil filter and air filter though....
And I must say that these guys are super pro! They even did a complete engine wash for me - meticulously cleaning EVERY item that has oil stain. Now my engine bay looks almost like new again! Hahaha!
If anyone here are feeling adventurous enough to head north to service your car, PM me for contact. Just to clarify, I'm NOT related to workshop in anyway. Just a happy customer after saving 90% of what the workshops here tried to charge me...
Hi there, care to share contact.?
I intend to change
1. Oil sump gasket
2. Vacumm pump O-ring
3. Water pump
4. Front shock absorber and brake pads.
5. Atf oil
Anybody got good lobang for this items pls advise.
Newbie , 2weeks old.
Thanks
You can get your part from a BMW stockist. If you'd google for "BMW stockist Singapore", Eng Soon comes out on top of the list. And this is also where many forumers here buy their parts from..... Good luck!! =)
I intend to change
1. Oil sump gasket
3. Water pump
5. Atf oil
Thanks
