canuck78
Re: Engine oil leak
The common cooling system problems lies with: hoses (can harden over time and leak), radiator (the aluminum fin develops fissures), water pump (last only ar 100k, before leaking), radiator fan, and expansion tank (can crack ar 80-100k as its made of plastic), etc.
Your workshop would usually do a cooling system pressure test to identify the problem areas. They should show you visually where it's leaking or white stains (dried up coolant) before you change the part.
But having said that, all the above parts are wear and tear items so sooner or later, you will likely end up replacing them all at some point in time.
Zincman;941593 said:last friday already change some of the hoses that need to be changed,only remarks by bvo is my radiator not good already but still can use.friday nite collect car but sunday afternoon coolant on the ground alady.today went to see them ,they told me is water pump leaking.i was shock but wat to do,replace the water pump plus assy.spent 5 hundred plus close to 6,if tomolo i checked my coolant again leaking ,i sure jump
