If no visible oil leaks around the engine bay area (usually black clumpy oil with dust), the seals or leaking on floor after overnight parking, then its usually internal leaks.
1 way to find out whether it is internal leaking (and burning internally) is to start the car after overnight parking, idle for about 10min, rev the accelerator hard at P or N and observe the exhaust.
If lots of WHITE fumes, then confirm internal leaks.
Happened to me and the usual culprit is worn VALVE SEALS. cheap spare parts but a little bit on the labour. I bought the seals from ES and went to one of the site sponsor to change them as warranty already over. No problem after that.
Since it will involve opening up of the engine, I took the opportunity to change ALL the valve cover gaskets, and oil pan.
Hope it helps
