F30: Wind noise updates
Re: F30: Wind noise updates
can use alittle Krytox to lubricate the door seals, or use OWS Body Flex Gel to remove rattling too.
ah ya..... my car kena delay to saturday or even monday.. thanks to slow pork land transport dept.. One number need to process that long meh...... 320i with carplate number 320.. sui
you should get no. plate 335 ... faster (i mean lta processing time) :D
Endure and dun give up , hahaha it is coming soon .
Can give under table donation to 'expedite'?
Just did a thicker additional door seal by a freelance guy, nice job under half hour!
Rule #1 - you need to clean surface using Rubbing Alcohol, easily purchase from Watson, remove wax, dirt and grease else the weather strip will not stick.
Rule #2 - be prepared that it will only last few months, as due to our heat, the strips will be deform and the double-sided tape will lose it holding power due to rain wetting them or car washer guys 'accidentally' push the strip during drying process.
Trust me, I bought those expensive $29 a box type from HomeFix to $2 a pack type from Daiso before. I regretted as I actually spend $ for this temp solution that eventually fail. And to this day, I decided to remove them and leave with the wind noise. Good night!
Click here to see some cheap and good ones from Daiso
I posted lots of reviews on DIY stuff on my [url]www.facebook.com/ilovemyride[/URL]
gemwinrestauranteclubcolo
