GB: Itronics In Car DVR
Re: GB: Itronics In Car DVR
Hey guys...I am one if the last Mohicans to join the gb for the itb100hd.
Heard some called wrong number.
Xavier's number is 84827998.
Btw, heard news bv2 still got overheat problem leh.
GB close can't buy? :(
Where the shop selling wanna get itb100
#01-88, Car Beauty
Kaki Bukit Autobay
scary place to drive into, like a place for sardines...where u will find the famous Hanip Automobile where the encik say mods no good for cars....haha
Got mine for usd230 for ITB100HD with power magic on eBay. But needa find a workshop to do installation.
Thanks Steven and WT! Go and do next week when my repair is done.
Has anyone figured out how to deal with comfort access going down when you
Have more than 1 camera?
I think power magic waste time. BMW car battery cut off cams way before power magic has a chance to do its work.
can elaborate on this? tks!
Have you experience before?
If i am not wrong, mine records even if comfort access is disabled. Yours doesn't?
I have just one ITB. I lose comfort access everyday, but Camera goes strong even after that. Powermagic cuts off the camera at about 16 hours.
I just checked, my DVRs don't shut down even after 12hrs (my setting) and go on recording (average 8-10 recordings at night). Comfort access is lost though.
Mine is set to Shock sensor sensitive and no motion sensor. I just set it to motion sensor sensitive and I'll take a look later today to see before leaving it overnight.
I think Kardtoon's prob is unique as he needs it to record quite consistently throughout the night and his batt lasts till 3am only.
my itb100-hd shutdown after 12hrs based on my setting :)
not sure is the power magic or bmw battery that cutoff the power
Since there are serveral pretty good reviews abt ITB100HD, I shall write about my installation instead...
Front cam:
Installation of the front cam is pretty much straight forward. Power Saver is tap to the fuse box located within the glove compartment. Try to place the Power Saver where you could access easily, in case you might wanna change the jumper settings. My settings are 48hrs and cut off voltage 11.8V.
Power cable run thru the pillar to the rear view mirror column. Wire is neatly conceal, except the part that run thru the rear mirror column and to the front cam
Rear Cam:
Installation of the rear cam is not as easy. Power Saver is tap to the boot fuse box located on the right side of the boot.
Rear bottom seat is removed in order to open up some space to run the power cable from boot to the cabin.
Run the wire thru the rear pillar to the top. Wire neatly conceal. Job done! Cams are good to go!
Tips: In order to take sure the fuse are tap correctly, what I did was off the engine and leave the boot and front passenger door open. Wait for a good 15mins for the electrical supply to cut off. When that happens, check both the Power Saver and ensure the power LED light up.
So far I also have minor problems like Comfort Access and auto folding mirrors not working in the morning. Both cams are sensitive, it does hibernate when there is no activities and rec when ppl walk past, and even when street lamps light up.
Lastly, I would like to thank Leslie who took the trouble to organise this GB. I have benefited greatly because my front cam's len has a permanent mark and it can be seen in the video. The supplier is helpful and honor the warrenty and did a 1-1 exchange with me. If I were to purchase via ebay, I would have to live with the lemon set! Cheerios :cool:
Btw, I did not do the installation at the supplier recommended workshop.
U installed yourself? If ur wiring kan salah, ur car door will open by itself when u r driving. Comfort exit
Nah. I spent some money and used Eye Power there... Be blogger and take pics...
wah , didnt know you can write so well.... wahahahaha
knn... lazy to write in queen's english... must ask SLK69 for suitable words...
Great writeup Centurion9990! You're welcome!
Let's try to troubleshoot whatever we can.
I parked for 7hrs and the batt drain showed but comfort access worked.
I'm trying to see how long before comfort access cuts off, for my car at least. I'll start my car at 10pm tonight and see if the comfort access works tom morn at 7am (9hrs).
As mentioned, i tested the 9hr break and the comfort access still worked. Tonight I'll test for 10hrs.
