vinlis77;986032 said:Hi Anyone experience this? Can advise? Was driving along the expressway and this warning light suddenly appeared. Stop the car and restart, the warning light cleared. Now has a constant fear the gear may kaput.
Like APNN car har??Meek;986055 said:I think it means flowers. Time for hanging flowers...![]()
Red_Bean_Bun;986188 said:got this once when engaging P at 100kmh ......
Red_Bean_Bun said:got this once when engaging P at 100kmh ......
vegadonovan said:I engaged P accidentally thought it's the button to open the roof. at 10KMPH. already seems like something going to spoil....
kenntona;986307 said:SOP answer - send two of you to a check-up
vinlis77;986334 said:Fault check. it's ratio differential....it's a sensor fault at gear housing assembly called RMFD mechatronics. this assembly (A3 size) contains the sensor and the 6 solenoids. cant replace the sensor alone which they don't sell separately. Got to replace the whole assembly plus change ATF, oil pan etc.
vegadonovan;986292 said:walau you da man. respect!
