Ground Zero BMW 1-1 Replacement Speakers & Woofer Made In Germany For All BMW Model
May I ask if the Ground Zero set (2x 4" speakers + tweeters) for X1 F48 compatible for newer X1 2020 version? If yes, can PM the price? Thanks!
Hi bro,
It's compatible!
Thanks
NEWLY Collected NEW BMW X1 F48 LCI From agent,came to us for Ground Zero 1:1 Replacement Of Speakers & Woofer!
Why Choose Ground Zero Over Other Brand:
1) No cutting & slicing of your original factory speakers wires
2) Plug & Play like OEM
3) (((Sound Quality Assured)))
4) (((Made In Germany)))
5) Specially design for BMW
Setup Consist Of:
- 1 pair of 4" replacement speakers
- 1 pair of 8" underseat subwoofer replacement
- 1 pair of tweeter
- 2dr STP Soundproofing
- 1 Pair Of BMW Original HK Retrofit Tweeter Holder
Call or WhatsApp Daniel https://wa.me/6596303880 for more info
BMW 1 Series F20 LCI Checked In For Ground Zero 1-1 Replacement Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
- 1 Pair Of BMW Original Retrofit Tweeter Holder
▶️Call or WhatsApp Daniel https://wa.me/6596303880 for more info◀️
We have demo car for Ground Zero 1:1 replacement of speakers & woofer with Ground Zero 4ch plug & play amp for customers to listen!
For appointment to listen,please call or WhatsApp Daniel @ 96303880!
BMW 1 Series F20 LCI after listen to our demo car,came back for Ground Zero 4CH plug & play amp w/plug & play harness!
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW!
Ground Zero 4Channel Specifications:
- 4 x 60W RMS @ 4ohm
- 4 x 100W RMS @ 2ohm
- 2 x 240W RMS bridged @ 4ohm
Above ratings are based on the CE-2006-A Standard
- Frequency response: 5Hz - 38 kHz
- Input Sensitivity: 02 - 5V
- Dimensions (w x h x l)
7.5 x 4.4 x 19cm / 2.95' x 1.73' x 7.48'
Features:
- High efficient compact amplifier
- 4 Channel fullrange class D
- 2 Ohm stable / 4 Ohm bridgeable
- Selectable active crossover (Full/LPF/HPF)
- LPF:30 -400Hz (12dB/Oct)
- HPF: 30 - 400Hz (12dB /Oct)
- 2 x Stereo RCA Input
- High-Level input with auto-on
Follow our Instagram: jdm_autocare
BMW 5 Series G30 From Original Factory Speakers,Upgrade To Ground Zero 1:1 Replacement Of Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
Follow Our Instagram: jdm_autocare
Another BMW 1 Series F20 LCI after listen to our demo car,came back for Ground Zero 4CH plug & play amp w/plug & play harness!
Features:
Pre Owned BMW 3 Series F30 LCI From Factory Speakers,Upgrade To Ground Zero 1:1 Replacement Of Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
hi there,
How much for my X2 set up?
Setup Consist Of:
- 1 pair of tweeter
Thanks
hi there,
Setup Consist Of:
- 1 pair of tweeter
Thanks
Kindly whatsapp 96303880 for faster response!
Thanks
I'm looking for a pair of retrofit tweeter mounts for the F48 BMW X1 to install tweeters in the doors. The original BMW Harman Kardon mount is to expensive here in Canada.
BMW X1 F48 Pre LCI From Factory Speakers,Came To Us To Upgrade To Ground Zero 1-1 Replacement Of Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
Staff online
