Ground Zero BMW 1-1 Replacement Speakers & Woofer Made In Germany For All BMW Model
NEWLY Collected BMW 5 Series G30 From Showroom,Came To Us Immediately For Ground Zero 1-1 Replacement Of Speakers & Woofer!
Thank you for the trust & support
Why Choose Ground Zero Over Other Brand:
1) No cutting & slicing of your original factory speakers wires
2) Plug & Play like OEM
3) (((Sound Quality Assured)))
4) (((Made In Germany)))
5) Specially design for BMW
Setup Consist Of:
- 1 pair of 4" replacement speakers
- 1 pair of 8" underseat subwoofer replacement
- 1 pair of tweeter
- 2dr STP Soundproofing
- 1 Pair Of BMW Original HK Retrofit Tweeter Holder
▶️Call or WhatsApp Daniel https://wa.me/6596303880 for more info◀️
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers,woofer & Ground Zero 4 Channel Plug & Play Amplifier is the perfect setup choice for your BMW.
BMW 5 Series G30 Checked In For GroundZero Full Complete Set Upgrade With Ground Zero Plug & Play 4 Channel Amplifier + 4dr STP Soundproofing!
Once again,thank you for your support
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of original BMW HK retrofit tweeter holder
- 4ch Plug & Play Radioactive Digital Mirco Amp
- 4dr STP Soundproofing
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW
Ground Zero 4Channel Specifications:
- 4 x 60W RMS @ 4ohm
- 4 x 100W RMS @ 2ohm
- 2 x 240W RMS bridged @ 4ohm
Above ratings are based on the CE-2006-A Standard
- Frequency response: 5Hz - 38 kHz
- Input Sensitivity: 02 - 5V
- Dimensions (w x h x l)
7.5 x 4.4 x 19cm / 2.95' x 1.73' x 7.48'
Features:
- High efficient compact amplifier
- 4 Channel fullrange class D
- 2 Ohm stable / 4 Ohm bridgeable
- Selectable active crossover (Full/LPF/HPF)
- LPF:30 -400Hz (12dB/Oct)
- HPF: 30 - 400Hz (12dB /Oct)
- 2 x Stereo RCA Input
- High-Level input with auto-on
NEWLY Collected BMW X2 F39 From Showroom In Da House For Ground Zero 1-1 Replacement Of Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
BMW 5 Series F10 Checked In For Ground Zero 1-1 Replacement Speakers & Woofer!
Thank you for your support
Setup Consist Of:
- 1 pair of tweeter
- 1 Pair Of BMW Original Retrofit Tweeter Holder
BRAND NEW BMW X3 G01 Checked In For Ground Zero Plug & Play Speakers & Woofer Setup!
Thanks For Coming Back To Us Again
Setup Consist Of:
- 1 pair of tweeter
BMW 3 Series F30 Checked In For Ground Zero 1-1 Replacement Of Speakers & Woofer!
Thank You For Your Support
Setup Consist Of:
- 1 pair of tweeter
BMW X1 F48 Came To Us For Ground Zero 1-1 Replacement Speakers & Woofer!
Setup Consist Of:
- 1 pair of tweeter
Thanks For Your Support
Setup Consist Of:
- 1 pair of tweeter
NEWLY Collected BMW X3 G01 Checked In For Ground Zero Plug & Play Speakers & Woofer Setup!
Setup Consist Of:
- 1 pair of tweeter
