Ground Zero BMW 1-1 Replacement Speakers & Woofer Made In Germany For All BMW Model
Another BMW 5 Series F10 Checked In For GroundZero 1-1 Replacement Speakers & Woofer!
Once again,thank you for the trust & support!
Why Choose Ground Zero Over Other Brand:
1) No cutting & slicing of your original factory speakers wires
2) Plug & Play like OEM
3) (((Sound Quality Assured)))
4) (((Made In Germany)))
5) Specially design for BMW
Setup Consist Of:
- 1 pair of 4" replacement speakers
- 1 pair of 8" underseat subwoofer replacement
- 1 pair of tweeter
- 2dr STP Soundproofing
- 1 Pair Of BMW Original Retrofit Tweeter Holder
▶️Call or WhatsApp Daniel https://wa.me/6596303880 for more info◀️
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers,woofer & Ground Zero 4 Channel Plug & Play Amplifier is the perfect setup choice for your BMW.
Another " NEWLY" Collected BMW 5 Series G30 Checked In For GroundZero Full Completer Set Upgrade With Ground Zero Plug & Play 4 Channel Amplifier + 4dr STP Soundproofing Powered By #GroundZero
Once again,thank you for your support
Setup Consist Of:
- 1 pair of tweeter
- 4ch Plug & Play Radioactive Digital Mirco Amp
- 4dr STP Soundproofing
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW
Ground Zero 4Channel Specifications:
- 4 x 60W RMS @ 4ohm
- 4 x 100W RMS @ 2ohm
- 2 x 240W RMS bridged @ 4ohm
Above ratings are based on the CE-2006-A Standard
- Frequency response: 5Hz - 38 kHz
- Input Sensitivity: 02 - 5V
- Dimensions (w x h x l)
7.5 x 4.4 x 19cm / 2.95' x 1.73' x 7.48'
Features:
- High efficient compact amplifier
- 4 Channel fullrange class D
- 2 Ohm stable / 4 Ohm bridgeable
- Selectable active crossover (Full/LPF/HPF)
- LPF:30 -400Hz (12dB/Oct)
- HPF: 30 - 400Hz (12dB /Oct)
- 2 x Stereo RCA Input
- High-Level input with auto-on
Another BMW 3 Series F30 Check In For Ground Zero 1-1 Replacement Speakers & Woofer!
Thank you for your support
2) Plug & Play like OEM...
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW original HK retrofit tweeter holder
All PMs Replied.
20% Off Retail Price Now For Ground Zero Speakers,Woofer & Tweeter Set!
Thanks,
Daniel
Classic BMW E92 M3 From Factory Logic 7 Speakers & Woofer,Checked In For GroundZero Full Complete Set Upgrade With Ground Zero Plug & Play 4 Channel Amplifier + 2dr STP Soundproofing Powered By #GroundZero
Once again,thank you bro Gabriel you for your support
Setup Consist Of:
- 1 pair of tweeter
Features:
BMW 5 Series G30 Check In For GroundZero Full Complete Set Upgrade With Ground Zero Plug & Play 4 Channel Amplifier + Rear Speakers Powered By #GroundZero
Once again,thank you bro Jon for your continous support
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of rear speaker + tweeter
- 1 pair of original BMW Harman Kardon retrofit tweeter holder
Features:
BMW F20 LCI Check In For Ground Zero 1-1 Replacement Of Speakers,Woofer & Tweeter!
Thank You For Your Support
Setup Consist Of:
- 1 pair of tweeter
Setup Consist Of:
- 1 pair of tweeter
BMW F20 LCI Checked In For Ground Zero 1-1 Replacement Speakers,Woofer + Tweeter!
Setup Consist Of:
- 1 pair of tweeter
- 4dr Double Layer STP Soundproofing
Setup Consist Of:
- 1 pair of tweeter
BMW F20 LCI Customer Came Back To Us Again Fpr Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW!
Thank You For Your Continous Support
Features:
Newly Collected BMW 5 Series G30 From Showroom,Came To Us For Ground Zero 1-1 Replacement Of Speakers & Woofer + Ground Zero 4ch Plug & Play Amp With Harness!
Once again,thank you bro Keith for your trust & support given to us
Setup Consist Of:
- 1 pair of tweeter
- 1 x Ground Zero Plug & Play Harness
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW.
Features:
Setup Consist Of:
- 1 pair of tweeter
- 1 pair Of Original HK Retrofit Tweeter Holder
Features:
BMW X4 F26 Came Back To Us Again For An Additonal 4ch Ground Zero Plug & Play Amp w/Harness Upgrade!
Thank You Bro For Your Support
Features:
Thank you for Your support
Setup Consist Of:
- 1 pair of tweeter
Another BMW 5 Series G30 Checked In For GroundZero Full Complete Set Upgrade With Ground Zero Plug & Play 4 Channel Amplifier + 4dr STP Soundproofing!
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of original BMW HK Retrofit Tweeter Holder
Features:
Call or WhatsApp Daniel https://wa.me/6596303880 for more info!
