Ground Zero BMW 1-1 Replacement Speakers & Woofer Made In Germany For All BMW Model
Look nice...
Mine is 535i GT F07, but I don't have the doors tweeters, still can retrofit?? How much for my car..
Hi bro,
You have PM.
Thanks,
Daniel
Ground Zero 1-1 BMW Replacement Speakers,Woofer & Tweeter Installed On Brand New 2 Series BMW F23.
Why Choose Ground Zero Over Other Brand:
1) No cutting & slicing of your original factory speakers wires
2) Plug & Play like OEM...
3) (((Sound Quality Assured)))
4) (((Made In Germany)))
5) Specially design for BMW
Setup Consist Of:
- 1 pair of 4" replacement speakers
- 1 pair of 8" underseat subwoofer replacement
- 1 pair of tweeter
- 1 pair of BMW original HK retrofit tweeter holder
- 2dr Dr.Artex Soundproofing
Contact Daniel @ 96303880 for more info
Ground Zero 1-1 BMW Replacement Speakers,Woofer & Tweeter Installed On Brand New BMW 3 Series F30 LCI.
2) Plug & Play like OEM......
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW original retrofit tweeter holder
Hi Daniel,
Can you PM me the price for F10 520 LCI c/w tweeter cover as well?
Thanks.
Hi bro,
PM Sent.
Thanks
Hello - Please PM the price to replace for F10. Thanks
Sorry unable to PM to your inbox,you might wanna check with the admin here.
WhatsApp me @ 96303880.
Thanks,
Daniel
BMW 1 Series F20 Came To Us For Ground Zero Speakers + Tweeter Upgrade With Original BMW Alphine Retrofit Tweeter Holder.
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW Original Alphine retrofit tweeter holder
▶️Call or WhatsApp Daniel https://wa.me/6596303880 for more info◀️
BRAND NEW BMW X1 F48 From Factory Speakers & Woofer,Upgrade To Ground Zero 1-1 Replacement Of Speakers & Woofer.
Setup Consist Of:
- 1 pair of tweeter
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers,woofer & Ground Zero 4 Channel Plug & Play Amplifier is the perfect setup choice for your BMW.
BMW 6 Series F06 Came Back To Us From Original BMW Hi-Fi System,Upgraded Into Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing Powered By #GroundZero
Once again,thank you for your support
Setup Consist Of:
- 1 pair of tweeter
- 4ch Plug & Play Radioactive Digital Mirco Amp
- 4dr Dr.Artex Soundproofing
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW
Ground Zero 4Channel Specifications:
- 4 x 60W RMS @ 4ohm
- 4 x 100W RMS @ 2ohm
- 2 x 240W RMS bridged @ 4ohm
Above ratings are based on the CE-2006-A Standard
- Frequency response: 5Hz - 38 kHz
- Input Sensitivity: 02 - 5V
- Dimensions (w x h x l)
7.5 x 4.4 x 19cm / 2.95' x 1.73' x 7.48'
Features:
- High efficient compact amplifier
- 4 Channel fullrange class D
- 2 Ohm stable / 4 Ohm bridgeable
- Selectable active crossover (Full/LPF/HPF)
- LPF:30 -400Hz (12dB/Oct)
- HPF: 30 - 400Hz (12dB /Oct)
- 2 x Stereo RCA Input
- High-Level input with auto-on
BMW 3 Series F30 Came Back To Us From Original BMW Factory Speakers,Upgrade Into Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing Powered By #GroundZero
Setup Consist Of:
- 1 pair of tweeter
- 4dr STP Soundproofing
Features:
BRAND NEW BMW 5 Series G30 Hybrid Came Back To Us From Original Factory Speakers,Upgraded Into Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr STP Soundproofing Powered By #GroundZero
Once again,thank you for trust & support!
Setup Consist Of:
- 1 pair of tweeter
- 1 Pair Of BMW G30 Original HK Retrofit Tweeter Holder
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW.
Features:
ok365social
