Ground Zero BMW 1-1 Replacement Speakers & Woofer Made In Germany For All BMW Model
All PMs Replied.
Thanks All,
Daniel
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers & tweeter is the perfect choice for your BMW.
Another BRAND NEW BMW X1 F48 from factory speakers upgraded into Ground Zero Speakers & a pair of Tweeter + Front 2dr Dr Artex Soundproofing.
Contact Daniel @ 96303880 for more info
1) No cutting of your original factory speakers wires
2) Plug & Play like OEM
3) (((Sound Quality Assured)))
4) (((Made In Germany)))
5) Special design for BMW
6) Compatible With All BMW Models
Setup Consist Of:
- 1 pair of 4" replacement speakers
- 1 pair of tweeter
- 1 pair of original BMW Harman Kardon retrofit tweeter holder
- 2dr Dr Artex Soundproofing
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers,woofer is the perfect setup choice for your BMW.
First BMW X4 F26 Installed Ground Zero Full Complete Set + Front 2dr Dr.Artex Soundproofing @ JDM Autocare!
Thank You Bro Wikee For Your Support.
(((Another Satisfied Customer On The Sound Quality)))
Setup Consist Of:
- 1 pair of 8" underseat subwoofer replacement
- 1 pair of tweeter
- 1 pair of BMW original retrofit tweeter holder
For more info,kindly contact Daniel @ 96303880
Worried about warranty issues for your new car on audio upgrade?No more worries,with no cutting & slicing of your original factory speakers wires,Ground Zero BMW 1-1 replacement speakers,woofer & Ground Zero 4 Channel Plug & Play Amplifier is the perfect setup choice for your BMW.
BRAND NEW BMW G30 came to us today & Installed Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing.
(((Another Satisfied Customer On The Sound... Quality)))
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW original Harman Kardon retrofit tweeter holder
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW
Ground Zero 4Channel Specifications:
- 4 x 60W RMS @ 4ohm
- 4 x 100W RMS @ 2ohm
- 2 x 240W RMS bridged @ 4ohm
Above ratings are based on the CE-2006-A Standard
- Frequency response: 5Hz - 38 kHz
- Input Sensitivity: 02 - 5V
- Dimensions (w x h x l)
7.5 x 4.4 x 19cm / 2.95' x 1.73' x 7.48'
Features:
- High efficient compact amplifier
- 4 Channel fullrange class D
- 2 Ohm stable / 4 Ohm bridgeable
- Selectable active crossover (Full/LPF/HPF)
- LPF:30 -400Hz (12dB/Oct)
- HPF: 30 - 400Hz (12dB /Oct)
- 2 x Stereo RCA Input
- High-Level input with auto-on
Another BRAND NEW BMW X1 F48 Installed Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 2dr Dr.Artex Soundproofing.
*Thank You Bro Melvin For Your Trust & Support*
Why Choose Ground Zero Over Other Brand:
Setup Consist Of:
- 1 pair of tweeter
- 4ch Plug & Play Radioactive Digital Mirco Amp
- 2pcs Dr.Artex Soundproofing
Features:
BMW F20 LCI Installed Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing Powered By #GroundZero
*Thank You For Your Trust & Support*
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW original alphine retrofit tweeter holder
- 4dr Dr.Artex Soundproofing
Features:
Higher Grade Of Ground Zero OEM BMW Replacement Speakers @ Affordable Price For All BMW Model.
GZ Setup Comes With:
- 1 Pair of 4" Replacement Speaker
- 1 Pair Of Tweeters...
- 100% Made In Germany
- Seperate Parts Available Eg: Speakers Only or Woofer Only
- Plug & Play
- Downtime 1hr+ To Install For Speakers or Woofer Only
(((SOUND QUALITY ASSURED)))
Contact Daniel @ 96303880 for more info & faster response.
I have a F20, please PM me the cost for this product.
Thanks
Return Customer BMW 4 Series F36 GC Came Back To Us Again & Installed Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing Powered By #GroundZero
*Thank You Bro Stanley For Your Great Support*
Setup Consist Of:
- 1 pair of tweeter
Plug & Play Ground Zero 4ch Plug & Play Radioactive Digital Micro Amplifier + Complete Harness cable special designed for BMW.
Features:
HOT Selling
From BMW 5 Series F10 to BMW BRAND NEW 5 Series G30 Came Back To Us Again & Installed Ground Zero Full Complete Set With Ground Zero Plug & Play 4 Channel Amplifier + 4dr Dr.Artex Soundproofing Powered By #GroundZero
*Thank You To My Good Bro Liang Hai For Your Great Support*
1) No cutting & slicing of your original factory speakers wires
6) We have most of the Fs & G30 Original BMW Retrofit Tweeter Holder
Setup Consist Of:
- 1 pair of tweeter
- 1 pair of BMW original HKup retrofit tweeter holder
Features:
HOT
From BMW 5 Series F10 Installed Ground Zero Full Set Of Speakers & Replacement Subwoofer In Feburary,Came Back To Us Again & Installed Ground Zero Plug & Play 4 Channel Amplifier + Front 2dr Dr.Artex Soundproofing With Even Better Sound Quality Powered By #GroundZero
Thank You To My Good Bro Clifford For Your Continous Support
5) Specially design for BMW
Features:
