Not too sure about the how the E90 works but in my case, whenever I send my car in earlier to PML for the oil change, they would just reset the meter again. If you're thinking of doing an oil change in-between at a workshop outside, there's no need to reset the meter. Just let it run till you bring your car back to PML for the next oil change.waynechai said:Plastic cracking sound on driver seat?
I have some "cracking" sound too.
It is absolutely annoying, more so than the whistling sound.
It turned out that there are som problem with springs in the seat.
Rodders...
Oil change at 12.5K...my E90 comes with BSI...can I drive in before the service indication is up?
Apparently, the mileage indication will/may change. When I got the car, it was 25,000. It is now 27,000.
The salesman said that that will vary according to how hard I drive the car.
Silver31 said:Perhaps during the next meetup, E90 owners should get together to share and exchange information on their ride. Any suggestions?
babe said:or a kopi session one of these nights...![]()
drivemax said:Hi,
Since you guys got yr E90 not long ago, did you guys feel the engine
is noisy when listen from outside? It sounds like a diesel taxi sound.
Mine sounds like that. Not sure whether it is still in its running-in stage as mine just slightly above 1k. :thinking:
RaptureM3 said:Got a secret to tell you..
The whistling noise is actually.. the secret supercharger under your bonnet. Don't tell anyone i told you.
tbt said:ok for me, i am on the East.
bt
