Loud screeching sound during braking.
Herman
Help!!!
Recently replaced my brembo brake pads due to wear and tear...
Initially when i heard the loud screeching noises, i thought it was cause the pads were new and haven't run-in yet.
But right now, after almost 2 weeks... The loud screeching sound still has not been solved.
It happens everytime i brake slightly harder... During hot/cold/wet/dry weather, before/after car wash.
Has anyone encountered this problem and has a solution?
I sound like a bloody lorry trying desperately to brake.
:whythis:
Re: Loud screeching sound during braking.
is it your rotor?
certain big brake kit has screeching sound when they are stopping.
change the whole brembo brake kit away lah. :nehnehhh:
Its the pads HErman, super hard thats why. Same as race cars, shiok
I got my brake pads changed recently too and I also noticed the screeching sound initially. But it went away after 2-3 weeks.
dude, you're not driving fast enough or braking hard enough... seriously...
you need to bed-in your brakes.
como;427557 said:
is it your rotor?
whirring - yes. screeching - prob not, unless you are on super aggressive race-spec pads.
axl;427582 said:
Other than "waiting for it to run-in", did you follow proper bed-in procedures, eg: StopTech : Balanced Brake Upgrades ?
+1. probably one of the best articles i've read on bedding-in brakes. explains how and why...
[email protected];427600 said:
anyway seriously, what pads u using?
most of the time he's on kotax or sofy...
this usually happen on race pads
he's on street pads.
simple solution: chamfer the edges of your pad, to create a distinct 45 degree bevelled edge. It will eliminate a large part of the squeak.
bwhaahahah Jin, kotax or sofy, post of the YEAR.
I thought it's common? Depending on what kinda screeching actually and 2 weeks is not long if you're talking about running in the brakes... What kinda distance have you done?
whats the brand of the pads. OEM brembo rotors? Also all calipers / rotors squealing or just 1?
ok365ok365com
