BT26;695496 said:heard from people that a stock M3 engine blew up recently. any opinions?
BT26;695616 said:interesting. so the rod bearings issue?
common to 2008 models
Samurai;695659 said:Sidetrack a bit....do you guys hear ticking sounds from your wheels after coming to a stop / park with engine shut off?
The ticking sounds are not intermittent but rather ticks at regular intervals like 5 secs each....thought it's normal, maybe the rotors cooling down or something...
Hopefully not the clicking sounds like the US folks mention..They claim to hear these when engine is running???:errr:
satinGHOST|r!der;695641 said:Well the part numbers for the bearings for 2009 models have changed. Some say its a change of manufacturer. But it could be also the higher rate of premature failures on 2008 models than the other years. But 2011 models also have had their share of failures, so it is really luck of the irish in every sense of the word LUCK.
Like I said if the part numbers for the bearings has changed and there are still failures, I say that some of the oil pumps on the car have gone bad. It's impossible that even after changing the bearings, these issues still surface. Remeber the S54 had the same issue before...
reardriven;695703 said:Interesting videos I must say.
The M3 purportedly hit 310km/h during the drag race with the 440bhp Evo. Can an M3 supposedly with only air filter mods, de-cat and exhaust hit 310? :chinese:
