need advise on brake change for e90
Re: need advise on brake change for e90
anyone know front rotor with 310mm and red color clipper was manufacture for which model of 3 series? it was on a e90 323i. rear was smaller rotor... try to search b4 online, 323i stock brake, m3 stock brake and more but couldn't found anythings similar to what i saw on a e90 323. it's looks exactly fit on it 18'' rim
Red_Bean_Bun;880727 said:
Back of the brake pads, pins, parts of the caliper etc.
Mind telling me which spray u using ? My OEM brake pads are giving faint screech sound while light braking I have tried bedding it doesnt seem to work.
Try this....
$9.80 @ Mustafa! =)
lkm;897892 said:
Try this....
$9.80 @ Mustafa! =)
Bought this yesterday after reading this thread. Used immediately and the squeal on by brake disappear.
But this morning after driving in the rain, the squeal seems to come back again.
By the way, how you reach the inner side of the brake caliper?
I got this and sprayed liberally on the entire caliper assembly as per directions. Squeal went away for 24 hr only. :(. Trying for a second time, and hoping for longer lasting results.
Jack up each corner of the car and crawl underneath for easier access behind each wheel. Else wait till the next rotation. Unless someone has some brighter ideas...
Maybe time to change brake pads...
Our car don't come with Jack up tools lah.
There is no spare tyre, most ride is with run flat tyres (RFT)
My fault for assuming the 3-series come with jacks. But they ain't difficult to loan, if there's really a need.
Anyone tried the "Low/No Brake Dust" Cool Carbon Brake Pads from Boss? Any feedback on it?? Really solve the Brake Dust problem??
Anyone here can help on this,
I had my front pads changed about a year ago, and my rotor changed about 2 mths ago. now gotten squeezing whenever i brake at low speed.
anyone had similar experience?
Did u change the brake pad when u replace the rotors?
Try the liqui moly anti squeal (not brake cleaner).
gk88charity
