Oil Pressure Check Light
enuun
My oil pressure check light came on yesterday. 2010 21k travelled. Anyone has the same problem so early? Thank you.
Re: Oil Pressure Check Light
well an update for the benefit of everyone.
sent to PML as still under warranty and they could not find anything wrong.
top up engine oil and the check light went off and wrote it off as low oil.
they could not tell me why pressure light came on instead of oil level light.
oh well, at least the coffee passable.
came on first time when engine start.
then will flash everything the car comes to a stop
Low oil level will lead to low oil pressure. Not enough oil to circulate. Hence likely why the oil pressure light came on. More importantly, check if there is a leak somewhere. engine oil levels do not usually drop for no good reason.
gemwinnavy
